Difference between 5w-30 and 10w-40?
08.05.2020 17:36 # 1
ahmet_bjk
Hello friends ...
What is the difference between 5w-30 and 10w-40 oil? (What are the advantages or disadvantages?)
& nbsp;
Which would be better to use? There is an oil called 30 c2 what is the difference from normal 5w-30?
08.05.2020 17:36 # 2
Viscosity is a term that indicates the resistance of oils to fluency. All engine oils are classified with the SAE serial number. The SAE nickname refers to the initials of the Association of Motor Vehicle Engineers (Society of Automotive Enginers) in the United States. The SAE standard of engine oils is regulated by this union. Oils with a smaller SAE number become thinner and more fluid. Oils with large SAE numbers become thicker and less runny. For example, oil numbered SAE 10 is thinner and runner than oil numbered SAE 30. Engine oils are manufactured in separate features for gasoline and diesel engines. In gasoline engines; Oils starting with the letter S are used, such as SA, SB, SC, SD. In diesel engines; Oils starting with the letter C, such as CA, CB, CC, CD, are used. Both gasoline and diesel engine oils; There are three types: summer, winter and combined oils (four season oils).
a) Summer Oils: SAE10, SAE20, SAE30, SAE40, SAE50 oils.
b) Winter Oils: Oils such as SAE5W, SAE10W, SAE20 W. The letter W determines that the oil is winter, is the first letter of the word winter in English.
c) Combined Oils (Four Season Oils): This type of oil is used in every season. Summer oil in summer shows winter oil in winter. However, it can never replace neither summer oil nor winter oil. These are oils such as SAE 10W - 30, SAE 20W - 40, SAE 20W - 50. For example; SAE 10W-3 O oil is used instead of SAE 10W oil in winter and SAE30 oil in summer.
08.05.2020 17:36 # 3
ByHack
Nice explanation "hll 206" .....
08.05.2020 17:36 # 4
If this question belongs to your vehicle in the signature 5W-30. If you take Castrol, you will get the C2 one.
