Diesel withdrawing diesel from 307
08.05.2020 19:01 # 1
huseyngunay
A friend of mine, a friend, I could not say that I could not give my car, but I do not want to give the tank full, because I did not come back like that, I tried with a hose, but it did not come.
08.05.2020 19:01 # 2
ahmet_bjk
There is a hand pump that pumps diesel into the diesel filter.
08.05.2020 19:01 # 3
byderebey
Well, if he is a friend who thinks about diesel, I can not give him a direct brother.
08.05.2020 19:01 # 4
Mesut48
[QUOTE]
Just as you usually give and be bad I think don't be bad, it is better.
08.05.2020 19:01 # 5
huseyngunay
[QUOTE = ahmet_bjk] There is a hand pump that pumps diesel oil to the diesel filter, you can remove the cable entering the filter and pump it with a hand pump, but it is very troublesome.
[/ QUOTE] I can't do it, I think we'll give the full tank for him, I can't say I can't
08.05.2020 19:01 # 6
Eric Cartman
The incident is very simple, insert one end of a 1.5 to 2 meter hose all the way to the bottom of the tank. Begin with your mouth on the other end. As soon as the diesel comes, take it out of the mouth and fill it into the container. Remember, the canister should be lower than the vehicle's tank.
You can swallow some diesel, it has a strange taste like oil, but at least it doesn't induce vomiting like gasoline: D
08.05.2020 19:01 # 7
KILIC
[QUOTE = huseyngunay] [QUOTE = ahmet_bjk] There is a hand pump that pumps diesel oil to the diesel filter.
[/ QUOTE] I can't do it, I think we'll give the full tank for him, I can't say I can't give it anymore [/ QUOTE]
Sorry, but I do not understand what you are calculating. You are giving 25-30 thousand lira vehicle. We are not good friends with you. I gave it to my friend just last week, bought the vehicle full tank empty and did not go to any trouble. If you say a friend, you can come to your eyes and you can fall into the same situation. Don't give a car, dont give the car and it will be bad, don't be bad
08.05.2020 19:01 # 8
okaNStarss
Take out the return hose to the fuel pump, install a pipe at the end, then start the car, then start the vehicle.
