Diesel Particulate Filter cleaner
08.05.2020 21:28 # 1
calkan
Hi ,
206+ 1.4hdi urban move last Sunday, the car protected itself, it started not eating gas, I was very bored when I took it to the master on Monday, there were institutions on turbo. When we connected it to the brain, it gave a particle filter warning. I just bought the car, it was not 1 month, I did everything but it gave a minimum warning, in addition to the diesel additive, I changed it on the inside of the left rear wheel. In addition, if I put the Diesel Particulate Filter cleaner into the warehouse in order to avoid the same warning again, would I have any problems before? Ermm
Thanks in advance.
the calker 2020-02-26 17:00:43
08.05.2020 21:28 # 2
Hello there,
If there are many institutions in the warehouse, there may be other problems. very rarely it is a situation that is encountered. First of all, v power diesel from the shell will be cleaned, use low gear high speed 10-15 minutes like the ring road. The reason for this clogging is caused by poor quality fuel at constant low speed and when used for the city.
08.05.2020 21:28 # 3
calkan
Hi ,
When I bought the vehicle, the Diesel Additive was giving the minimum warning, I had a new one filled up. After going 2,000 km, I took the engine to protect it, I did not delete it right now. Since I bought the vehicle, I did not take it from another place from the shelves.
As an additional question, I changed all the filters, including the diesel filter when I bought the vehicle, but the warning about clean the diesel filter still gives this error because there is no original part.
Thanks,
08.05.2020 21:28 # 4
GokhaN
[QUOTE = calkan] Hello,
Thanks,
As you probably said, the diesel filter is not the original one that most parts sell for our vehicles.
08.05.2020 21:28 # 5
calkan
In the next maintenance, I will buy the original one and try it :)
