Diesel particle filter
08.05.2020 17:46 # 1
meister
Hello friends,
Is there anyone who clearly knows whether there is a particle filter on my 307 XT 1.6 HDI (110 HP), 2005 or will I be able to propose an address on the Internet?
Or let me ask you what engine oil is originally used for this vehicle?
10W40?
5W30? (I think this is only for particulate filters)
I bought a mobile brand 10W40 to go for maintenance but 5W30 will change and go.
thanks for your answers ..
08.05.2020 17:46 # 2
tlp
I think you can get help from here
http://www.castrol.com/castrol/sectionbodycopy.do?categoryıd=9041330&contentıd=7074757
08.05.2020 17:46 # 3
meister
I bought my vehicle now at 88 thousand in 111 thousand and it will be the second maintenance after I receive it.
1) I will replace the air, pollen, oil and diesel filters.
2) I will put 5W / 30 oil.
3) "additive (fap liquid) filling time" in the maintenance period for the particle filter is called 120 thousand km. What an expensive liquid and do you think I should expect 120 thousand?
3) I am also thinking of having the brake fluid checked.
Do you think there is anything else I forgot? or your suggestions?
thanks.
08.05.2020 17:46 # 4
meister
According to the code of the vehicle written in the chassis no, my vehicle does not have a particle filter. According to the user manual, there are two types of engines in 1.6 hdi. The type of engine in my vehicle that I show with the red arrow in the picture.
Also, for those who say which engine oil should I choose, Mobil 1 recommends:
meister 2013-07-04 17:07:16
08.05.2020 17:46 # 5
cerci07
1.6 110 hp has a particle filter and particle-free models, generally experienced 5w30-5w40 is recommended for particulates. vicinity :)
possible to cancel
08.05.2020 17:46 # 6
Mustafa-almanya
If the vehicle is used for a short distance, I know that the particulate filter tank is emptying earlier.
08.05.2020 17:46 # 7
meister
[QUOTE = onurazgin] [QUOTE = meister] I have bought my vehicle in 111 thousand at 88 thousand now and it will be the second maintenance after I receive it.
Thank you. [/ QUOTE]
Normally there are 120 thousand yes, but there are those who fill in 80 thousand .. If there is no fap in your vehicle, it means no problem: D, but let me warn you about the diesel filter. check the window water, renew the engine water, you will put antifreeze in the winter. If you can, get carbon clean. clean the air flow meter with lining spray. Add 0/30 oil, mobilinki very good castrol unnecessarily expensive .. [/ QUOTE]
I bought a delphi brand as a diesel filter. The filtermaker said this was the original part for my vehicle.
What do you call an air flow meter? I do not know that!
