Diesel Paper Clipper Stop
08.05.2020 21:10 # 1
Huseyin_Koroglu
Selamun aleykum,
Diesel 206 stops when my car shifts into 2 gear. It goes smoothly in 1st gear but when it turns on the headlights, it stops in 1st gear. Is there anyone who can help?
08.05.2020 21:10 # 2
First of all, welcome to us. there may be many reasons.
A one-havadebimetr
2-crank speed sensor
3-battery
4-Charger and Conjector
5-electrical installation
6-engine ecu
7-bsi
My teacher may have a problem with one or more of them. First, have your car checked the error codes with the original software.
08.05.2020 21:10 # 3
Huseyin_Koroglu
We are welcome, Hodja,
Let me see what the problem will be for the electrician
08.05.2020 21:10 # 4
The most dominant part of the electrical installation is that my teacher may be doing chassis somewhere. I hope it is a simple problem, and the problem will be handled properly.
08.05.2020 21:10 # 5
Huseyin_Koroglu
It seems to me that it is related to software, it goes in 1st gear, after all, does it go in 1st gear if it is electrical?
08.05.2020 21:10 # 6
My teacher goes, but the trouble is when you turn on the headlights or when any function is activated in the electrical system, it causes a short circuit, which may affect the vehicle's fuel system. Is there a system made later in the vehicle (sound system - exnon etc.)
08.05.2020 21:10 # 7
Huseyin_Koroglu
My teacher stops the headlights before I open the 2nd gear.
The owner before me built the sound system, the cables were pulled, but nothing was plugged in.
08.05.2020 21:10 # 8
In my opinion, my brother will cover the cut cables with macaroons as I said. When it shifts into second gear, does it stop without pulling the clutch or after pulling?
08.05.2020 21:10 # 9
Huseyin_Koroglu
When it pulls out of the clutch, it stops shaking.
08.05.2020 21:10 # 10
Huseyin_Koroglu
Sir, the problem was solved by itself or postponed. Since the malfunction lamp did not light, they could not see the problem either. You look at it when the fault light goes on, they said everything is normal in sight. For 3 days there was nothing, today he kicked twice a second but did not stop.
08.05.2020 21:10 # 11
I think that the weather has been good for a long time, oxidation or water has entered the sockets.
08.05.2020 21:10 # 12
Designbyonurkaya
[QUOTE = Huseyin_Koroglu] My teacher solved the problem spontaneously or postponed. Since the malfunction lamp did not light, they could not see the problem either. You look at it when the fault light goes on, they said everything is normal in sight. For 3 days there was nothing, today he kicked twice a second but did not stop. [/ QUOTE]
I am sick, do not you understand when the malfunction lamp is not lit up by such masters tavsiye my brother advise me look at the crankshaft sensor look at the cables the car stops, shakes everything, the screen may also not malfunction
08.05.2020 21:10 # 13
Huseyin_Koroglu
That day is no problem for this day, but today it made a second misfire on the 3rd gear, it continued without stopping. As if electricity is gone :)
08.05.2020 21:10 # 14
Huseyin_Koroglu
I write if it happens to you. Problem found. Clutch sensor malfunctioned it has changed.
