Diesel less my cars with LPG after the last hikes |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 14:11 | # 1 |
| 08.05.2020 14:11 | # 2 |
burns less than 55 liters of storage 950-1000 who road ..
| 08.05.2020 14:11 | # 3 |
[QUOTE = EmRaH] burns less 55 lt tank 950-1000 km road .. [/ QUOTE] dude makes 55 liters on average 150 ytl edo 150 km per 1000 km in these gas cars 1.6 vehicles with 20 million gas 140 150 km gıdao buda 135 thousand 140 thousand liras & nbsp; I heard that an average of 1.2 or 1.0 tube corsa trees burned 100 thousand on the long road. water & nbsp; I have a friend at 2.0 206 GTI KM MIXING 180 THOUSAND YAKIO |
| 08.05.2020 14:11 | # 4 |
[QUOTE = CIHANGIR_DONMEZ] [QUOTE = EmRaH] less burning tab 55 liters tank 950-1000 km road .. [/ QUOTE] dude makes 55 liters average 150 ytl edio 150 km 150 thousand 1000 vehicles in these gas cars with 20 million gas 1.6 vehicles 140 150 km gıdio buda 135 thousand 140 thousand lira & nbsp; I heard that an average of 1.2 or 1.0 tube corsa trees burned 100 thousand on the long road. water & nbsp; I have a friend at 2.0 206 GTI KM MIXED 180 THOUSAND YAKIO There is a bonus in the gas you burn beside the gas in this case :)
| 08.05.2020 14:11 | # 5 |
cerci07 |
The question you ask changes from your car to your car, if you want a horse and motor proportion for example, the new cikan bmw 320d 2L engine with 168hp 4.9L100km you can compare this power with a lpg li-vehicle |
| 08.05.2020 14:11 | # 6 |
friends, we grew up in the industry, it burns a little, let's not start a war because it burns less, let me convey that gasoline engine work 2 python head fuel turns into a dark & nbsp; Since gasoline has weaker pressure than diesel, & nbsp; double piston force is required to turn the crank strongly. In diesel, the event is very different, if the single piston is jammed and dried, it bursts strongly, and if the single piston is enough to turn the crank arm, with the reinforcement of the turbo, we provide 2 simple bursts for the same crank movement in gasoline. In half, at half LPG, the gas cannot burst as strong as gasoline and the crank arm does not rotate at full power, in fact, fuel is injected to the injection or carburetor, but it seems that it burns less because lpg is cheaper than gasoline comment your < br> |
| 08.05.2020 14:11 | # 7 |
Nobody "started this war because it burns a little", where did you get it from polatkap? (Slightly out of place) Friends are just comparing the fuel rates of their vehicles. In addition, speaking in capital letters means shouting and is prohibited by forum rules. Please don't repeat.
| 08.05.2020 14:11 | # 8 |
Can Duzyatan |
Even if lpg and diesel consume the same amount after the last hikes, I would love the eyes of the diesel. ![]() At least, diesel vehicles can enter the parking lots of the shopping malls or something. ![]() |
| 08.05.2020 14:11 | # 9 |
Can Duzyatan |
[QUOTE = eminönal] In addition, speaking in capital letters means shouting and is prohibited by forum rules. Please don't repeat. [/ QUOTE] Caps Lock remained open. ![]() Microsoft Word - We went small with format ![]() |
| 08.05.2020 14:11 | # 10 |
Whenever you go to the center of the shopping mall, do not you understand whether your friends stop or look: D
| 08.05.2020 14:11 | # 11 |
As someone who used to use gasoline-LPG vehicles before, I do not dismiss Haşim master's determination. Since the transition time from gasoline to gas takes 3-4 minutes in the lpg system, the amount of gasoline spent by the vehicle in idle is a considerable amount. I think there are also performance vehicles.
| 08.05.2020 14:11 | # 12 |
Can Duzyatan |
[QUOTE = EmRaH] every time you go to the shopping center, do not you understand the pause and your friend's voice: D [/ QUOTE] What do we do if you always fall into rubble ![]() ![]() |
| 08.05.2020 14:11 | # 13 |
Kemal |
Diesel vehicle always burns little, but maintenance is a bit expensive
| 08.05.2020 14:11 | # 14 |
[QUOTE = Kemal] Diesel vehicle always burns little but maintenance is a bit expensive [/ QUOTE] no be kemal abi .. everything is the same money .. the same oil the same filter .. the walking is the same .. the same accessory .. turbo pattern is now produced with high pressure in gasoline vehicles, only one pump left is left, it will not easily cause problems if you are careful when buying diesel.
| 08.05.2020 14:11 | # 15 |
Kemal |
I will buy 307 diesel, there are 306 sedans for sale.
| 08.05.2020 14:11 | # 16 |
[QUOTE = hasimayaz] [QUOTE = CIHANGIR_DONMEZ] [QUOTE = EmRaH] less burning tab 55 lt tank 950-1000 who road .. [/ QUOTE] kanka 55 liters average 150 ytl edo 150 km per 1000 km makes this 20 cars. 1.6 vehicles with gas 140 150 km gıdao buddha 135 thousand 140 thousand lira I have heard an average of 1.2 or 1.0 tube corsa trees burned 100 thousand on the long road at the moment. diesel fuel is less than yakıo price, close to gas, lpg is the same as gasoline in lpg, but it has half price with gasoline. There is a bonus in the gas you burn beside the gas in this case :) [/ QUOTE] you are right in that regard, if we do not count the first of the gas consumption of the gas, the same volume tube and diesel is the same, the tube is very little, the difference is less, but there is a difference in performance between 1.4 and 1.4 diesel. There are plus licensing exams, parking, etc. operations are problematic, but when I took my car to love it, I counted a lot of money when I bought a tup. |
| 08.05.2020 14:11 | # 17 |
if you get good lpg (italian systems lovato, zavoli, tartarini) lpg vehicles always burn less maintenance costs are less than diesel, it does not pollute the environment, there is no difference from gas in traction |
