DIESEL INJECTOR CLEANING PROCEDURE
08.05.2020 18:13 # 1
samet2461
I FEED THE FUEL WURTH MIX THAT YOU SEE IN THE PICTURE BY DISABLING THE TANK AND DIRECTLY SUCTION MANIFOLT. I RETAINED AT THE ROLETTE AND 2,000 SPEEDS, AND AFTER THE MIX, I CONNECTED THE TANK AND GIVEN A SOLID GAS. THE MIXING ENDED ABOUT 1 AND A half HOURS. RESULT WONDERFUL & nbsp; "Big
samet2461 2014-01-19 20:15: 37
08.05.2020 18:13 # 2
ahmet_bjk
doesn't it harm the vehicle?
where are the scraps cleaned?
How do you know it works?
why did you need it?
I think I asked some more questions :)
08.05.2020 18:13 # 3
korkusuz202
Yes, if you explain in a little detail, everyone will be informed. I have a question. It is too much for me to run for 1.5 hours.
08.05.2020 18:13 # 4
samet2461
brothers my car had been throwing a little black smoke when I looked through the mirror at high revs, I made it from it. there is no harm. I run it for 1.5 hours because the fuel drug mixture was too much, you put it in less, it ends early, it takes a short time. My vehicle is currently not smoking at all. moreover, my catalyst is empty.
When a friend said the wastes are going, the process is finished and when it gives solid gas, an institution throws nothing from the exhaust. I asked, I did it, they said no problem. I tried it has no problem. that's all
08.05.2020 18:13 # 5
sarp
THIS SECOND TRANSACTION THAT SHOULD BE ABOUT AGAIN, WHAT WILL YOU PREPARE DIRECT WATER AND WHAT YOU HAVE DIRECT VURTH?
08.05.2020 18:13 # 6
Burak
Will this incident affect the performance of the car, positively or negatively?
