Diesel Injector
08.05.2020 17:46 # 1
halilefe
Hi friends car 206 Hdı 1.4 I did not want to handle the master I do not know about the injectors of my vehicle.
08.05.2020 17:46 # 2
halilefe
http: // www. ***. com / Peugeot-206-iNJECTOR of-the-14HD 0445110252, PR-3558.html & nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; I found an injector like this, but I couldn't find a more reliable net, the master said it cost me 900.00 TL.
08.05.2020 17:46 # 3
halilefe
http: // www. ***. com / Peugeot-206-iNJECTOR of-the-14HD 0445110252, PR-3558.html & nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & nbsp; & nbsp;
& nbsp; I found an injector like this, but I couldn't find it more reliable than the net, the master said it cost me 900.00 TL. I do not think that such things have happened to me.
08.05.2020 17:46 # 4
mustafa_nalcacioglu
What kind of problem is there, can you tell me a little bit about how many kilometers of the vehicle?
08.05.2020 17:46 # 5
halilefe
No misfire and low traction when running no click when it was running, the starter now needs to hold the starter for 4-5 seconds. It works almost like a Tractor & nbsp;
08.05.2020 17:46 # 6
mustafa_nalcacioglu
The masters say that it is 100% injector, or you guess? There is no misfire in mining draft. What should be related to working before it should be looked at. When the diesel filter has changed, it may cause problems in the first operation. my battery does not like at all, my friend has a pug bipper, when the battery is weak, injector error data was hard and it worked hard. I suggest you take total excellium diesel and use it a little bit, it makes a lot of difference & nbsp;
08.05.2020 17:46 # 7
cocomo
You may be mixing the injector with the heating plug.
The problem you mentioned may be due to spark plugs ... I have just changed 4 spark plugs, what did it hold 120 pounds .... 70 percent probability heating spark plugs ... 30 other probability starter system, coal dynamo, battery etc.
as if it has nothing to do with the injector.
I can also say that 4 injectors have changed,
If the injectors have congestion, dysfunction, and misalignment, the car will be singles, not gas, can run jerky, burns a lot, throws smoke, even there are moments when you can't even go half a clutch.
Cocomo 2013-07-07 16:04:57
08.05.2020 17:46 # 8
halilefe
No misfire gas & nbsp; and no black smoke discharge problems, but shaking during operation, too much fuel consumption for 2-3 weeks.
08.05.2020 17:46 # 9
halilefe
I was buying from PO, I changed the diesel urgently, it was connected to the computer in the industry and they said that they missed the 2 injectors that they could not provide feedback.
08.05.2020 17:46 # 10
mustafa_nalcacioglu
I guess your car may have a problem such as fuel leakage from injector hoses at around 150 thousand km of these engines, or there may be the same leak in the diesel return hoses. As far as I know the chronic problem of the motor, you will see the hoses. I already said like the serum hose.
08.05.2020 17:46 # 11
mustafa_nalcacioglu
Bidet has come to my mind now, when you don't start the car for at least all of the time, start the diesel air pump without pressing the starter, if it is too soft and look at the light transparent diesel pipes before it. Due to these problems, the injectors may not be getting enough pressure or the fuel may not return & nbsp; it may not be detected as an injector failure.
If there is no problem, consider the bidet carbon clean event before the injector change. .
mustafa_nalcacioglu 2013-07-07 19:42:22
08.05.2020 17:46 # 12
emre koksal
the problem is that the injector does not disassemble it, they do not recommend the insertion of the injectors ... the ankara did not bother, I had it made it hold 60 tl last year ... >
& nbsp;
if the car is running hard, look at the mars dynamo ...
and & nbsp; does it feed back to the battery, alternator and charge control ...
the battery may not be enough anymore ...
& nbsp;
08.05.2020 17:46 # 13
cocomo
I made the injector carbon. I am very satisfied. Göral said that 4 injectors will completely change. I had the carbon cleaning in the mischief and just replaced the nozzle of the injector & nbsp;
kept 200 tl instead of 4 billion. and the problem has been fixed. service doesn't deal with it, of course ..
