diesel fuel filter error?
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 16:29 # 1
just307
my friends parked my car 2 days ago without any problem, when i wanted to run it today it gave an error called `` preserving water in diesel fuel filter '' when i press the contact, there is a click, click, click, the lights are flashing, the error sound is short and the opposite is the next it gives success, what is the problem? Thank you for your help already? There was no such error and malfunction in my vehicle before, when I opened and closed and pressed the ignition once again, it gave the first error which I said as breaking system faulty, that is, brake system malfunction. Sounds came in a cuddly style? Can anyone help?
08.05.2020 16:29 # 2
hallowman2005
Do not try to run Just307 tool, find a master and have your diesel filter checked. It is not possible to say anything definite from here, but there may be a problem with water or a foreign substance in fuel, or a problem with the diesel filter and sensors.
Get well soon
08.05.2020 16:29 # 3
I must state that if the battery in your vehicle is weak, BSI can introduce such errors. How's your mind doing?
Does your car never print? So the mars engine doesn't freeze?
koliva 2011-12-29 18:34:05
08.05.2020 16:29 # 4
hallowman2005
[QUOTE = koliva] I should mention that if the battery in your vehicle is weak, BSI can generate such errors. How's your mind doing?
Does your car never print? So the starter motor does not freeze?
Koliva can display some error messages that do not have the right low battery, you can test this situation by transferring from the simplest.
08.05.2020 16:29 # 5
yavuz25
There is water in the diesel filter according to the error that my friend gave. It reminded me that it is at a long time. There is a water drain valve, open ax. If you know.
08.05.2020 16:29 # 6
just307
As I said, when I first pressed it started, but it didn't work, in my next attempts, it did not start, it just sounds like plug and play and the signaling is blinking, it might be as you say, because I normally use my car every day, I can say for the first time, I did not run it for 2 days. let me try an experiment, the best for cvps.
08.05.2020 16:29 # 7
yavuz25
Do not reinforce it, it may be bad. Do not reinforce the car with water. "Wink"
08.05.2020 16:29 # 8
just307
yavuz25 yes the error says something like this when you turn it, but would there be water in the filter that prevents the vehicle from working? My vehicle is not working right now and the starter does not turn the engine. Maybe I find wherever you describe the valve you said in my car, 2006 307 1.6?
08.05.2020 16:29 # 9
just307
What can be done, if the problem is on the battery?
08.05.2020 16:29 # 10
yavuz25
You will buy 0 batteries and do not reinforce by following the rules. If the brain is damaged, you cannot get out of the job.
08.05.2020 16:29 # 11
yavuz25
[QUOTE = just307] yavuz25 yes the error says something like this when you turn it but would there be water in the filter to prevent the vehicle from working? My vehicle is not working right now and the starter does not turn the engine, the valve you said maybe find it wherever you describe it in my vehicle, 2006 307 1.6? .But in our vehicle, there is a valve in the filter and the hose coming out of it. You open the valve and look at the transparent pipe and tighten the hand diesel pump. What happens if it squirts? The mother of the engine cries. For this, your vehicle is protected. "Wink" < / div>
08.05.2020 16:29 # 12
yavuz25
You can crash on the spot where you bought the latest diesel to repair your vehicle in service. "Wink"
08.05.2020 16:29 # 13
hallowman2005
If the problem is on the battery, you will check the water of the battery, if it is missing, you will add water, and if it is not resolved, you will get a new battery. Don't worry if you follow the reinforcement rules, there will be no problem in your vehicle.
& nbsp;
& nbsp;
& nbsp;
in the battery; Be careful to have the same capacity at 12V voltage
2. Make sure that your vehicle does not come into contact with the vehicle you are supplementing. Member 3. Turn off unnecessary lamps and accessories on both vehicles. Member 4. Connect the positive (+) end of the jumper cable to the positive (+) end of the empty battery and the other end to the positive (+) end of the reinforced vehicle. Connect the negative (-) end of the cable to the negative (-) end of the charge battery. Attaches the other & nbsp; end of the negative (-) cable to a non-moving metal part or cylinder block. Connecting the cable to the negative (-) terminal of the empty battery & nbsp; & nbsp; because it can cause sparking & nbsp; from the battery. Member 5. If the battery of the vehicle providing electricity is weak after the connections are completed, start the engine of that vehicle and leave the engine running. Member 6. If the engine does not start immediately, wait a few minutes and try again to allow the discharged battery to take off. Member 7. Then start the engine of the charged vehicle. Immediately disconnecting charging cables after engine starts. Let the engine run for 5 minutes & nbsp ;. 8 Reviews. Carefully unfasten the jumper cable. Remove the negative (-) and then the positive (+) leads.
& nbsp;
hallowman2005 2011-12-29 22:38:47
08.05.2020 16:29 # 14
yavuz25
dude it doesn't mean to risk unnecessary. The prices of CSI and other electronic components are burning so you know it very well. A battery weighs a maximum of 120 pounds. "height =" 17 "width =" 17 "border =" 0 "alt =" Wink "title =" Wink "/>
08.05.2020 16:29 # 15
hallowman2005
"Big & nbsp; Well, as you said Yavuz. Actually you're right, no need for unnecessary risk
08.05.2020 16:29 # 16
yavuz25
[QUOTE = hallowman2005] "Big & nbsp; Well what you call Yavuz be like. Actually you are right, no need for unnecessary risk [/ QUOTE]
My brother is all right for us. We write what we know right after all. "border =" 0 "alt =" Wink "title =" Wink "/> I have always respected people's ideas and themselves. "Smile"
08.05.2020 16:29 # 17
just307
I made reinforcements, following the rules and the vehicle worked, it doesn't give any error at the first press.
08.05.2020 16:29 # 18
[QUOTE = just307] I reinforced the rules and the vehicle did not work at the first press. The trip computer did not turn on the malfunction lamp, today I will measure the battery. "0" alt = "Smile" title = "Smile" />
Get over.
koliva 2011-12-30 11:47: 34
08.05.2020 16:29 # 19
yavuz25
[QUOTE = just307] I reinforced the rules and the vehicle did not work at the first press. The trip computer did not turn on the malfunction lamp, I will measure the battery today. "height =" 17 "width =" 17 "border =" 0 "alt =" Wink "title =" Wink "/>
08.05.2020 16:29 # 20
just307
I would like to repeat for cvp again, otherwise I would call the authorized service unnecessarily, pull the car and change the diesel filter on top of it.
Page : / 2
