Diesel fuel filter
08.05.2020 15:51 # 1
m1976k
Friends, it is time to change the diesel filter of the vehicle. There are 2 kinds of filters. One of them is around 50 TL and the other is 110 TL. Koliva 2011-07-19 19:01:08
08.05.2020 15:51 # 2
berk2309
In my opinion, the cheap one will damage the injectors to the engine, the cheapest one will last 2 years, the quality is 5 6 years. As Sakıp SABANCI said, "I am not rich enough to buy cheap".
08.05.2020 15:51 # 3
berk2309
Also, as far as I know, sometimes cheap side industry filters can cause an error in the brain or sometimes it can cause problems such as not working.
08.05.2020 15:51 # 4
Do not look for it to be cheap or expensive. Using the most beautiful original peugeot product.
08.05.2020 15:51 # 5
The diesel filter is not used for 5-6 years. It depends on how many kilometers it is. Buy the original original, which is expensive, is one in the box, plug it, use 40 km and change it.
08.05.2020 15:51 # 6
berk2309
My brother Emrah, I read the pump in the first place, and I saw it later.
08.05.2020 15:51 # 7
m1976k
you are right, it is useful to use the original ...
08.05.2020 15:51 # 8
[QUOTE = m1976k] Friends it is time to change the diesel filter of the vehicle There are 2 types of filters, one of them is around 50 TL and the other 110 TL is cheap.
my friend is using bosh brand 55 TL .. I couldn't understand what is 110 TL I wonder they put a spare one in the trunk Gülme
08.05.2020 15:51 # 9
meanwhile, the guarantee is a change of 20 thousand
08.05.2020 15:51 # 10
m1976k
[QUOTE = pugti] [QUOTE = m1976k] Friends it is time to replace the diesel filter There are 2 types of filters, one around 50 TL and the other 110 TL, do not install the cheap one. Can you share your experiences? [/ QUOTE]
[/ QUOTE] which is the delphi brand, what does it write on the original?
08.05.2020 15:51 # 11
desert197
friends, there is a check valve so that the diesel coming to the engine does not escape after the stop is stopped. This check valve is in the diesel filter. .
08.05.2020 15:51 # 12
atakanka
[QUOTE = NiyO] [QUOTE = m1976k] Friends it is time to change the diesel filter of the vehicle There are 2 types of filters, one around 50 TL and the other 110 TL, do not install the cheap one. Can you share your experiences? [/ QUOTE]
I will go to industry for oil change tomorrow. When I bought the car, 144,000 were now at 162,000. I am thinking of changing the diesel filter. Shocked
08.05.2020 15:51 # 13
cerci07
[QUOTE = atakanka] [QUOTE = NiyO] [QUOTE = m1976k] Friends it is time to change the diesel filter There are 2 types of filters, one about 50 TL and the other 110 TL is cheap, do not you share your experiences? [/ QUOTE]
Excuse me when you bought the vehicle
normally the diesel filter varies between 40 and 60 thousand. I changed it to 80 thousand depending on the usage. I did not have any problem.
I am sure that the filter they give as original is not as good as bosch or man
cerci07 2011-09-30 23:22:12
08.05.2020 15:51 # 14
atakanka
So when I buy it, I know that the oil was changed but the diesel filter was not changed. If it is changed at 40,000 km, the vehicle has arrived at 160,000 now, which means that the 4th change has come.
frankly, the vehicle is my first vehicle and it feels a little inexperienced. It's been 1.5 years.
08.05.2020 15:51 # 15
sahin-peugeot
Friends, the list price of this filter is 71.83 TL only, there is no heater sender above the original, you should wear the sender over the old one.
The campaign price of the original box filter is 50 TL http://www.peugeotmarket.com/index.php?do=catalog/results
Bosch brand has a price of 70 TL, and there are Chinese goods sold for 40-50 liras.
08.05.2020 15:51 # 16
m1976k
I went to my master to let me change the time, so I was comfortable, he asked me when it was last changed, I said it was 20 thousand, I asked if there was a problem in the operation of the vehicle, he asked me if the indicator light was on, he said there was no problem in him, the master said, there is no need, he said that he could go 40 50 thousand I said thank you I left ..
08.05.2020 15:51 # 17
erkan7884
Does the car sound when the diesel filter is worn out?
08.05.2020 15:51 # 18
tellotello
[QUOTE = erkan7884] Does the car make sound when the diesel filter gets old? [/ QUOTE]
I don't think it will make a sound, my teacher gives a fault about dirty diesel on the screen and generally the vehicle's operating time changes or does not work at all, because when he thinks that the diesel filter has lost his duty, he thinks that the diesel is problematic and does not allow use in this case.
