Diesel float?
08.05.2020 18:38 # 1
nonick
Friends I bought the vehicle 206 2006 feline 1 month ago, I usually get 50 TL or 20 TL for the first time but I bought 100 TL but it does not come to the point it should be but the hand is moving, the old owner will recover. Yesterday there was a short circuit from the lighter, I changed the fuse, it was okay, it was not working.
08.05.2020 18:38 # 2
okaNStarss
Check all fuses from the fuse panel in order, if there is no problem, use it for a while.
08.05.2020 18:38 # 3
mistercasper
The general situation of my teacher is that the next time you will improve your fuel intake (at least 40-50 rubles), do not worry, it is a simple event.
08.05.2020 18:38 # 4
nonick
I understand, let's wait, but it is not possible that the contact is on the vehicle.
08.05.2020 18:38 # 5
cansytnn
just like the tank cover is opened with contact, my 307 does not accept 30 TL diesel, definitely it will be over 30, otherwise the needle is still lit as light, there is no play, there is no 30 TL diesel
08.05.2020 18:38 # 6
nonick
Friends still do not click 20 TL more than the first
We got it right now, but it should be halfway but if I look at the bottom or if I shake my car :)
NoNiCK 2014-06-26 21:39:35
08.05.2020 18:38 # 7
BurakCnR
My brother, if you can give me advice, make sure your tank is full and the problem will be fixed. Don't waste your time.
08.05.2020 18:38 # 8
nonick
How much does this melet fill up if I fulle? There is already half a tank, I think we have researched, there is a calibrator, the last resort is to remain full.
08.05.2020 18:38 # 9
nonick
I decided to finish the warehouse and try it that way, but no more clicks :)
08.05.2020 18:38 # 10
suppor
I think 50 liter tank can be filled to 200 for sure
08.05.2020 18:38 # 11
lead38
Don't worry, we do it all the time.
08.05.2020 18:38 # 12
xdesign_206
The same incident happened to me, I said it would be okay, I used it for 2 months, but it did not, then I went to the service and calibrated the buoy, and it did not repeat.
