Diesel Filter, Oil Change Vs.
08.05.2020 14:06 # 1
Friends greetings,
1-Diesel filter will change every few minutes. The master is not a frequently changing piece as long as you take the diesel from the clean place, he said. I still have to change it. It would affect the performance of the vehicle.
2- We put the oil 10/40 Elf. We were hesitant to put 5/30? What is the most suitable oil brand for you? How many will it be?
3- I have a sound system to get out of my old car. When I install an audio system in the vehicle, I would make any electronic malfunctions. What kind of precaution can we take if we think the amp draws a lot of current?
4- Everyone gave different views for the Triger set. Authorized service exchange how many thousand.
Thank you for your answers
VEHICLE 307 PRe.HDI 110BG 2006 MOdel.
08.05.2020 14:06 # 2
I can comment on the sound system :)
yes, the right amp draws a lot of current, I was draining the old battery :) I bought a new battery + I don't plug the cable right now. will be
08.05.2020 14:06 # 3
hasimayaz
Ideal for diesel filter is one in 20,000. But peugeot's filters are a bit more complicated so you can change it every 30,000 depending on the diesel you use.
You used the right oil.
Since the trigger part of the audio system draws electricity continuously, it may cause the battery to run out. But if you start your vehicle at least once in 1-2 weeks, it is not a problem.
It is appropriate to replace the triger at 80.000.
08.05.2020 14:06 # 4
ErkanKurnaz
[QUOTE = Serkan] Friends greetings,
My dear brother, good luck, may Allah not cause an accident
Also let me answer humblely from my own experience
1. I changed my car as soon as I bought it. As my master hasim said, let's change it in 2 oil changes. I do not know the performance part, but if there is water left in it, it will cause trouble.
2. I put castrol 5/40 edge as oil, as soon as I change the oil, I recommend it to anyone who realizes the sound is a bit expensive but :)
3. I don't understand much from this part :))
I know that the 4th timing set changes at 90.0000, but since I did not trust anyone, I changed all the belt sets (timing, alternator belt, tension balls etc.) in the month I bought my car. it explodes a little but your head is comfortable. Also, if the timing breaks, the bill is a bit sad.
08.05.2020 14:06 # 5
First of all thank you for the answers
[QUOTE = hasimayaz]
I usually listen on the move. Can we damage the ECU, which is called the Brain when it is finished? It is certain that we will break it shortly. it happened to me.
[QUOTE = Ellis]
After the CAPACATOR is bought, it will balance the flux power between the battery and its amplifier .
Is this capacitor expensive?
[QUOTE = erkankurnaz]
Thank you bro, stay away from everyone
It's like staying on the road when you say trouble. expensive expense etc. did. Doesn't it drain the water? How do I know what breakdown it gives?
08.05.2020 14:06 # 6
kpasator varies between 120-150 TL. most sound system users use
08.05.2020 14:06 # 7
cerci07
good for your vehicle
There are two separate 110 hp engines used in 307s, there are 2 liters and 1.6 16 v ones here.
1.6 is the same engine as my 206
I recommend replacing the diesel filter here at 80.000. I changed it at 100.000.
It writes 5/40 as an oil in the user manual
timing set on the herkeze different bisey soyluyor but pugeot 160,000 BMD up guaranteed to have a sudden to tell about this incident turkiyede ford particle ford FiesTTa the TDCi's (1.4 HDi) timing strap of 50,000 also was captain of my team me a by saying it changed the vehicle came to 110 thousand here, somehow I went to a mechanic I asked if I wanted to change tirgel apricot and balls or something, they asked how many thousand km of the vehicle was, I asked, they looked from the pc and they said that there was a factory warranty of 250,000 km and 10 years, and we repeated the same thing because of the mistake.
I am doing the oil change at 20,000 and it is written in the manual
you better ask a service at a night Thumbs Up
08.05.2020 14:06 # 8
cerci07
By the way, 80.000 fap filter is changing. If you do not replace a filter below the catalyst, it will malfunction at 100.000. Angry I know mine will change
08.05.2020 14:06 # 9
I emailed Peugeot Customer Service yesterday. They called today and said the Timing belt first change for My Car is 180,000 KM.
08.05.2020 14:06 # 10
Doktor
I also own 2004 307, when I bought it, I checked it from the service. The employee in the service is my close friend; He said that 75,000 triggers had changed and that I did not need to change it again for 10 years.
He stated that there is no need to change the diesel filter frequently. However, my vehicle was at 87,000 km and when we said that it had to change at 90,000 km, we decided to replace it. Of course I do not know as much as the technical team in our forum, but I have written to contribute as far as I have had :)
08.05.2020 14:06 # 11
everyone gives a different KM, but the best thing is to change it in 5 years regardless of KM It comes to my mind that services can make early changes for profit. Peuget or not Turkey will also vary 180,000.
08.05.2020 14:06 # 12
lamazibici06
can be changed every 15 thousand
