Diesel filter clean warning
08.05.2020 18:57 # 1
izzet
Friends wrote the warning of clean diesel filter while going out on the ramp with my new 206+ 2012 diesel vehicle, we changed the filter, said the master has broken the filter cover, we changed it again, yesterday I saw a ramp again, when he came to 3000 revs to try the vehicle, he wrote the warning of clean the diesel filter again. anybody experiencing this type of malfunction? I wonder if any other filter is available between the diesel pump and the filter from where it originates.
08.05.2020 18:57 # 2
okaNStarss
I think have the entire system checked by a pumper. There may be malfunctioning sensors on the software site or this type of problem may occur when the filter industry is available.
08.05.2020 18:57 # 3
izzet
I do not think that it will soon be going through the filter, but I think that the incoming fuel is insufficient. Let's see what it will take some time.
08.05.2020 18:57 # 4
izzet
Yesterday I went to the industry, the breakdown particle filter was removed, removed, cleaned back, and deleted the computer from the failure.
08.05.2020 18:57 # 5
uzunca961
Is there any trouble again?
I think the contribution gives little error. Do I need to clean it?
Can you give the phone of those masters, if any
uzunca961 2015-07-24 09:57:49
08.05.2020 18:57 # 6
burakbaykal2
Greetings from my teacher Ankara. I have the same vehicle 2010 1.4 HDI. If you replaced the diesel filter and did it again, it is most likely a sensor error. There are small 2-piece sensors on the filter bowl bed. Ivedik also have a good peugeot master if you want to give your phone or show me your address. I don't think there is a big problem.
08.05.2020 18:57 # 7
uzunca961
Sir, the citizen I bought the vehicle said new filters.
I am in Güngören / Istanbul. If it is close to me, I will go and see it.
08.05.2020 18:57 # 8
Semaviseyyah
What do you want to answer?
08.05.2020 18:57 # 9
uzunca961
I took it to the service Kagithane Elmas a. Filled from the market cheaper particle additive warning gone uzunca961 2018-12-12 22:03:00
08.05.2020 18:57 # 10
GokhaN
[QUOTE = uzunca961] I took it to the service Kagithane Elmas a. Fill the market cheaper particle additive warning gone [/ QUOTE]
In fact, if it does from the particle, it should have given a small amount of particulate fluid on the screen, but it should still be past.
08.05.2020 18:57 # 11
uzunca961
Already particle fluid gave me little error
30.05.2020 09:19 # 12
pdr42
I have the same warning. To clean the diesel filter. I thought of the particle filter when I visited the forum, the particle filter warning is not as far as I understand. Let's make this fuel filter my oil filter friends clear this issue. I think it's a fuel filter, right?
01.06.2020 11:28 # 13
uzunca961
[QUOTE = pdr42] I have the same warning. To clean the diesel filter. I thought of the particle filter when I visited the forum, the particle filter warning is not as far as I understand. Let's make this fuel filter my oil filter friends clear this issue. I guess it's not a fuel filter [/ QUOTE] Hello, I don't think the car will give a warning for the fuel filter. I do not know when the car was last serviced, but if it has been a long time, it is useful to change the fuel filter while it is being maintained. If the problem still persists, there is something like blockage in the fuel hose after the filter, but it gave this warning because the fuel is too low.
