Diesel 206 Fuel Gauge Problem
08.05.2020 16:09 # 1
djbaddua
Hello friends, I have a 2004 model diesel 206 car. I said, fill it up, they gave 8 pounds of diesel, the diesel fuel of the huge gas station was finished. Naturally, the light did not end, so I went 30 km more, I bought fuel from the 90 lira opet. The pointer continued to fall and I stopped in the parking area, waited for 10 minutes, and then when I started the car again, the medicine was raised. I said, sorry, if you have any information about what is the solution to this problem, I would appreciate it. Thank you.
08.05.2020 16:09 # 2
Something similar happened to me. I filled the tank again in 3/4, the needle did not play, I made 200km road and approached the half. i filled it again but it took 11lt. but it was still in the same place. I went to the service, they calibrated the float. Fixed
08.05.2020 16:09 # 3
djbaddua
How long did you keep caliber work in service, teacher.
08.05.2020 16:09 # 4
MaximuS
Is this also a chronic problem ...? the same thing happens to me from time to time ... even the first time I was in Adana. I asked the pumper over and over again to ask him how to refill and took the man's sin. What is this calibration job, how much does it cost?
08.05.2020 16:09 # 5
The vehicle was under warranty, I did not give money, but it took 2-3 hours.
08.05.2020 16:09 # 6
Fuel normally taken under 10 liters is not reflected in the needle. In other words, at least 10 liters of fuel are required to increase the needle. & Nbsp;
Also, the vehicle must be stopped and started again. Did you stop the car when you bought 90TL gasoline? & Nbsp;
08.05.2020 16:09 # 7
MaximuS
the question is not me, but I would like to answer it as someone who has experienced this problem. I do not buy diesel for less than 50 TL, usually 100 TL. I buy lik. sometimes the next day the needle rises. even very funny; again, he had not moved from the needle, after taking the fuel, I had a very hard right-hand maneuver while I was on the road. The first run is also buoy. and pointer & nbsp; rising ... & nbsp; "Embarrassed"
MaximuS 2011-09-27 00:31:32
08.05.2020 16:09 # 8
djbaddua
It gives 50 liters of 13 liters or something, I stopped after taking 90 TL but the hand did not play, then I did 50 km or so, the needle was falling for 10 minutes.
08.05.2020 16:09 # 9
taskin
I have a similar problem but I keep the road with 100 TL in total and try not to light it. But while I am buying a mosaic, I stop the car and open the tank cover with the ignition key, and after the filling process is over, when the door of the driver is opened, all the hands come down to that position and come back to that position. My guess is that the indicators are reset, I don't care much anymore .... The service said the buoy should change, then it should be cleaned, when I heard the price, I stopped doing it.
08.05.2020 16:10 # 10
djbaddua
Thank you for your answers and interest, I bought the last 50 TL of fuel. The needle came to itself.
08.05.2020 16:10 # 11
Saleeh
I have strange things about the needle:) & nbsp;
When the tank was empty, I bought 150 TL of fuel from the shelter. When I got into the car and looked at the tank, it was almost full and I told him to fill it up and told the pump to fill it. It took about 25 TL more and the pump threw. However, when I got into the car, the needle was in the place I looked after getting 150 TL. He experienced the same incident in my brother when the vehicle was in my brother. There is no problem right now but in the hand :)
08.05.2020 16:10 # 12
[QUOTE = Saleeh] I have strange things about the needle:) & nbsp;
Cunku 25 TL / fuel unit price & lt; 7 liters.
08.05.2020 16:10 # 13
Saleeh
[QUOTE = koliva] [QUOTE = Saleeh] I have strange things about the needle:) & nbsp;
I bought 150 TL of fuel from the shelter when the tank was empty. When I got into the car and looked at the tank, it was almost full and I told him to fill it up and told the pump to fill it. It took about 25 TL more and the pump threw. However, when I got into the car, the needle was in the place I looked after getting 150 TL. He experienced the same incident in my brother when the vehicle was in my brother. There is no problem right now but in the hand :)
Should it be more than 7 liters or more than 10 liters?
08.05.2020 16:10 # 14
[QUOTE = Saleeh]
Should it be more than 7 liters or 10 liters?
7
08.05.2020 16:10 # 15
10lt at 307 1,4 HDi. I have experienced several times.
