Did we gasket
08.05.2020 18:27 # 1
muhammed.ceyhan
My friends car 2000 model 206 xr 1.4 petrol + lpg.
This morning I checked the oil of my car. A layer of buttermilk is formed on top of the water inside the tank that feeds the radiator.
I put my finger in the water and my finger became completely fat. (Brown). You can see that it has mixed with water. However, I did not see my water mixture in the oil cubes. I did not start the car. For what happens.
Question 1: Did the car burn out?
Question 2: I did not heat the vehicle. Was the gasket burned because the thermostat did not open?
Question 3: How much does it cost me and how long does it take to repair?
Thank you for your answers in advance.
08.05.2020 18:27 # 2
ismailkaya
I guess the gasket will take you to the people of the job.
08.05.2020 18:27 # 3
ahmed206
I don't know if the gasket has burned or not, but that top cover will open. Because you will not be comfortable.
When I bought the car, I had it too, the gasket was not burned but missed. The best advice I can give you is not to waste time. Go to a clean master. I believe it will be cheaper to buy parts online. In addition, I recommend you to replace the timing set circulation pump etc. even the radiator because the cooling system parts are always ignored in maintenance.
Get well soon.
08.05.2020 18:27 # 4
muhammed.ceyhan
I changed the triger 15000 km ago. I did not force the vehicle on the basis.
I don't use it hard. In the d100 I go between 90-100 gears at 2500 rpm
I raised. I am thinking of changing the circulation. We'll open the top cover, that's for sure.
what do you think this job explodes to me
08.05.2020 18:27 # 5
muhammed.ceyhan
Also, when I was ramping for about 4-5 months or when I hit the gas on the straight road, a scratch came from him. Could it be related to this
08.05.2020 18:27 # 6
ahmed206
Gasket 80-100 Lira
Circulation Pump 70-80 Lira
Oil filter vs 100 Lira
Master 250
600 pounds maximum
08.05.2020 18:27 # 7
muhammed.ceyhan
Thank you. I think I will drop the master fee a little more. We know the master. it looks like we will spend 500 papers.
08.05.2020 18:27 # 8
ahmed206
You're welcome. If the master does not fall too much, do not envy :)
He also opened the valve adjustment (he will most likely offer himself).
08.05.2020 18:27 # 9
emrepunar
If the engine burned the engine gaskets, if you realized it early, but as far as I know it costs a lot. The parts inside the engine are changing again, I do not want to give any wrong information. Get well soon.
08.05.2020 18:27 # 10
muhammed.ceyhan
[QUOTE = ahmed206] Thank you. If the master does not fall too much, do not envy :)
he wants a suitable fee anyway. my father's friend for years. we don't bring many others to our vehicles anyway.
valve setting in mind. When the temperature was in the 90s it works like a diesel vehicle.
08.05.2020 18:27 # 11
muhammed.ceyhan
[QUOTE = emrepunar] if the friends burned the engine gasket maybe if you realized it early but as far as i know it costs a lot. The parts inside the engine are changing again, I do not want to give any wrong information. get well soon. [/ QUOTE]
Thank you very much. I hope we can handle it cheaply. hayirlisi. such things will happen. mechanical result.
08.05.2020 18:27 # 12
kursat3006
Never change gaskets directly, firstly clean the spare au tank, drain the water completely, renew it. If it happens, then follow the contta path.
08.05.2020 18:27 # 13
ahmed206
Kürşat, if an oil has entered there, you can clean it in a week, but you can not be sure of it, 6 months later, the oil molecules come out of it.
Smile
08.05.2020 18:27 # 14
muhammed.ceyhan
[QUOTE = ahmed206] What if Kürşat entered an oil there, you can clean it in 1 week, you can not be sure of it, 6 months later, the oil molecules come out of it.
Smile
08.05.2020 18:27 # 15
muhammed.ceyhan
water in vehicle repair. No trouble on the cap. Stoned to death. let's see what will happen.
