Did the car drop water to the ground we stopped? |
| 08.05.2020 20:56 | # 1 |
| 08.05.2020 20:56 | # 2 |
Hi You are talking about how much water drop.
| 08.05.2020 20:56 | # 3 |
Well, my teacher was a 2-3 cm drop, but the other day I looked it was full. there is no water left. I showed in the industry they could not find water leakage. I think steam is flying now in this heat :)
| 08.05.2020 20:56 | # 4 |
There is no leakage, brother, there is a leak. ![]()
| 08.05.2020 20:56 | # 5 |
The water in my Peugeot 206,2004 model decreased, so the radiator had changed. I had LPG in my car and when I went to have LPG adjustment, it showed water leakage at the LPG connection points.
As Selçuk55 said, there is a few in one place, you have to have a good master. |
| 08.05.2020 20:56 | # 6 |
There is definitely a leak, under normal conditions, the vehicle will not stop water, I recommend you to use it with an appropriate diluted antifreeze after the problem is corrected.I recommend that you first check the radiator, lower, upper hose etc. for leakage. |
