DIAGNOSTOTIC FAULT LIGHT
08.05.2020 16:45 # 1
ali1980
friends 2003 model 307 gasoline & nbsp; antipollition shows fault malfunction I heard it from the air filter I changed the filter then reset the malfunction memory after using the tool for a while again giving the same fault for your help thanks for your help
08.05.2020 16:45 # 2
efe1988
I think it is the fuel combustion rate because it is an oxygen probe
08.05.2020 16:45 # 3
I wish you had a look at the error while deleting the prayer. What error did you delete on the shift?
08.05.2020 16:45 # 4
aacemm
same problem in me p2191 error code I delete it again, but only lpd is causing problems, no problem on gasoline.
