diagbox 7.82
08.05.2020 20:34 # 1
SCREAMN
I downloaded Labtopa diagbox, the language was in Turkish, but when I updated it to 7.82, the language became English. How can I do it in Turkish?
08.05.2020 20:34 # 2
maximusti
According to the installation notes in me:
You have to do TR instead of EN, FR
one.
If DiagBox language is french:
Open the File Explorer and navigate to "C: AWRootdtrd rans", find the file "Language.ini" and create a copy "Language.ini.org".
Open the file Language.ini and under [LANGUAGE], change "Current = fr_FR" to "Current = en_GB" and save (I commented the original and added the change from French to English).
[LANGUAGE]
; Current = fr_FR
Current = en_GB
2 a.
For DiagBox Lexia (Tested with DiagBox v.7.83):
Navigate to "C: APPLEXIAEXE" and find the file "DICO.TXT".
"DICO.TXT" is a read only file, so rename it to "DICO.TXT.org".
Create a copy of "DICO.TXT.org" and then the copy rename it to "DICO.TXT".
Open the file "DICO.TXT" and change Dico = THELEXBG.DBZ to Dico = THELEXGB.DBZ and save.
This is enough to change to english.
The following suggested to change only if language not solved from above procedure (probably you didn`t do it correct):
Navigate to "C: APPLEXIAEXE" find the file "langue.ini" and create a copy "langue.ini.org".
Open the file "langue.ini" and under [DicoMap], change all "% LG%" to GB (I commented the original 4 lines and added changed 4 lines).
[Dicomap]
; CITACT dicocıtact% = .. LG .dbz%, APV
; CITTT dicocıttt% = .. LG .dbz%, APV
; CITTV dicocıttv% = .. LG .dbz%, APV
; THESA the LG = .. dicothesa% .dbz% of APV
CITACT = .. dicocıtactgb.dbz APV
CITTT = .. dicocıtttgb.dbz APV
CITTV = .. dicocıttvgb.dbz APV
= .. dicothesaugb.dbz THESA of APV
08.05.2020 20:34 # 3
SCREAMN
Thanks.
