Description of Fault Codes
08.05.2020 21:27 # 1
ckaya
Hello, good morning, the Peugeot family. I have these 3 error codes in my vehicle. I know that one of the spark plugs is not working, I want to get information about whether they are related to it or if there are different problems.
P1351 - P1598 - P0490 FAULT CODE
08.05.2020 21:27 # 2
FatihBall
Hello, first of all, I would like to remind you that the codes you receive are universal codes.
Your first mistake spark plugs give missfire error,
Second error The first error related to the turbo valve can trigger it.
The third mistake is related to the dirty of the throttle. If it does not improve when it is cleaned, potentiometer replacement is required.
08.05.2020 21:27 # 3
oguzhan53
In the psa group diesel, 1351 fault code is caused by the failure of the heating spark plugs, this problem is encountered at the age of 4 or 5 years old.
08.05.2020 21:27 # 4
ckaya
There is no problem in my car right now, I was just curious because it was on the list. I think the first 2 errors are normal because one of the spark plugs does not work. I will clean the throttle and scan it again. I write the result here. Thank you for giving information.
I couldn't clean the throttle =)
MCA to 2020-02-20 09:04:19
