Derman to Derman
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2009-2015)
08.05.2020 21:17 # 1
mavi5071
First of all hello to everyone.
My friends vehicle 2009 model 3008 1.6 HDI diesel semi-automatic. At 138 thousand Km.
I bought it last year, this year (2019) I changed the clutch pressure pad set at the end of June. But one month after the printing renewed the pad, my vehicle did not work one day. Masters were said to have a Brake Switch malfunction and we replaced it. Although it is 1 week after changing the brake sensor, my vehicle frequently gives the same error (this breakdown, which usually shows up by not automatically shifting from 1st gear to two during heavy traffic, allows me to use the vehicle manually and to upgrade gears manually, but to park the vehicle and switch it off after starting the ignition. I have to pull the auspler a bit) We couldn't figure out why this error didn't go away completely. If you have knowledge or experience in this matter, please help.
08.05.2020 21:17 # 2
KILIC
Could there be a problem with the newly installed brake sensor?
08.05.2020 21:17 # 3
mavi5071
By chance. A brake sensor that I had previously installed had a fault code at a distance of 300 meters. It appeared on the computer as "track incompatibility" and I replaced it with what is on it now.
08.05.2020 21:17 # 4
ismailkaya
If I was in your place, the print goes to the place where you changed the pad, this tool never worked one day and I encountered such a problem. I would check the car again. Then I parked my workplace, I finished my work again, I wanted to get on my car again, the car did not work, the starter was not working, all the functions are working, but I was not receiving the starter, I called the service 3 hours ago, I received the car, but my car is not working at the moment, I said I stayed on the road, I gave my car information, these operations were done, I said to my car, they sent a tour service. The team took care of 20 minutes, I asked the service staff what the problem is, the problem is due to us, while collecting the vehicle, they couldn't fit one of the sensor, they put it on. had been eliminated.
