depolution system faulty
08.05.2020 16:25 # 1
masezer
Today, the message "depolution system faulty" appeared on the p 308 vehicle display at 105,000 km. the vehicle stops by pressing the gas pedal. Peugeot suggested that I take it to the service center with the tow truck. I have a knife where the tool is .. Is there anything I can do ...
08.05.2020 16:25 # 2
djchaos
1. Pollution pollution depollution means cleaning-cleaning. This mistake is only evident in cars with diesel particulate filters. 2. When you receive this fault notification, if there is a drop in engine power, a misfire with gas, stop right there and do not do any more. Wait about 10 minutes (stop the engine) before calling the service. If it gives the same fault when you restart it, call for service and seek assistance. 3. If the fault light goes out after 10 minutes, continue the road, but check if there is a problem with the car's gas supply. Also check if it is kicking when traveling with fixed gas. If there is no problem, you can continue. In this case, even if the lamp is reflected, if there is no problem in the operating characteristics of the engine, you can continue on the road. Because the ECU memorizes this malfunction and can sometimes report back by reading it from memory even if the error is corrected. 4. So why does this fault report? This is one of the most common notifications of the PSA group. If you run the cold engine constantly and over km. If you stop without doing it, run it again and stop and stop the engine without warming up, it can make this malfunction notification. Cleaning is not possible because the engine has not reached enough heat. If you ask what is cleaning, of the diesel particulate filter. In order for the harmful particles in the filter to be removed, that is, to be expelled from the exhaust, the engine needs to reach sufficient heat. If this is not achieved and when it is stopped while it is constantly cold, the ECU can report this error as a result of the inability to clean the particles accumulated. 5. Of course, this is not the only reason. A momentary inaccurate measurement of the sensor measuring the air flow can cause the turbo pressure to temporarily rise or fall. While this is not related to the cleaning system, it may be related to the injection system, which may result in a malfunction. 6. Poor quality fuel or small dirt mixed with fuel can cause temporary or permanent clogging in one or more of the injections. In this case, it also signals a malfunction and the motor may be cut off from power, misfire. In this case, you should definitely not continue on the road. I wanted to inform the car users who use the PSA hdI engine of Peugeot, Citroen and Ford.
08.05.2020 16:25 # 3
djchaos
[QUOTE = masezer] Today, the message "depolution system faulty" appeared on the p 308 vehicle display at 105,000 km. the vehicle stops by pressing the gas pedal. Peugeot suggested that I take it to the service center with the tow truck. I have a knife where the tool is .. Is there anything I can do ...
connect your vehicle to the computer, I recommend you to see the fault, even if the fault lamp turns off automatically, it keeps the ECU registered in the brain and it is useful to connect it to the computer even if you go to the smallest thing. -12-03 22:44:04
08.05.2020 16:25 # 4
baris558
It is a little old topic, but I said I would share my information.
I bought a 2007 407 1.6 diesel vehicle 3 days ago. The vehicle is a beautiful and well-maintained vehicle. But there are some problems with second-hand vehicles. I bought the vehicle from the island. As for Sivas, depollution system faulty. The piss came out again. I went to a few places including the authorized service.
Glow plugs broke out. I changed.
I checked the EGR valve. It turned out solid. I had it cleaned.
I had carbon clean.
In the meantime, I had the turbo pipes checked. There was no problem. I had the dust and fuel filter checked, & nbsp; just changed.
After these, the engine malfunction lamp went out by itself. I deleted the errors again. Fortunately for the moment it did not make any mistakes again. For example, I gave these errors together with an error called esp-asr faulty. I had skidding in the first gear, I saw that esp is engaged. No one, including the authorized service, could see an error. They said the fault warning was caused by the other fault warning.
08.05.2020 16:25 # 5
baris558
Again, I got the same error, but this time I followed a different path.
I'm writing for information.
What they say is very good in the industry I went to the masters. If I caught myself, they would change many parts of the vehicle. Starting from EGR to the air flow meter.
Then I went to the Sivas Peugeot Authorized service. Best of the services I have seen so far. I felt like at home. Professionals and craftsmen in their work. They didn't say let's change that. They did their complete checks. They found the turbo solenoid valve to be faulty. The problem has been solved. They did the vehicle in a general maintenance. The vehicle became a completely different vehicle. It was like a shotgun.
I think we need to encourage such dealers. I would like to thank Yusuf bey and Bilal Beye, Mrs. Damla (they questioned the satisfaction at every moment of the process) & nbsp; Ahmet Bey is a young and talented friend. He is doing his job devotedly, scientist.
