Depollution system faulty
08.05.2020 21:21 # 1
Zafer Dincer
My 407 car gives this error
They said clean the fuel tank, replace the diesel filter, I made it from the service but it did not improve again.
This is what I have to do, I would be glad if you help
08.05.2020 21:21 # 2
iso0625
I need to look at the error code on the device, hodja.
08.05.2020 21:21 # 3
Zafer Dincer
tmm thank you act according to the code i will write to you
08.05.2020 21:21 # 4
Zafer Dincer
error codes P1197 and P0562
08.05.2020 21:21 # 5
iso0625
A problem with low voltage does not seem to be related to my teacher diesel. System gives injector circuit failure and keyless voltage low error. A good electrician can solve it. There may be a problem with the cable or socket.
08.05.2020 21:21 # 6
Bayer
I had this problem in my 207 vehicles. There was a malfunction in the coils, the warning went away when the defective ones were replaced.
08.05.2020 21:21 # 7
Zafer Dincer
in which coils?
08.05.2020 21:21 # 8
Bayer
There were 4 coils in my vehicle. The spark plugs connected to the coils may also need to be replaced. did you take it to the master?
08.05.2020 21:21 # 9
Unfortunately there is no coil in diesel vehicles, only glow plugs are available. When it comes to problems, your car's charging connector is probably faulty because it causes unbalanced voltage production, which can cause injectors to fail. First of all, have your vehicle's voltage values measured.
