Depollution faulty I couldn't find solution
13.11.2020 03:15 # 1
cimariva
Hello. I have the 2006 model 1.6 hdi 110 hp 307. Engine light came on with depollution faulty warning while driving on the road today. Particle filter came to my mind. But the car does not exceed 3 thousand cycles in any way. It comes up to 3 thousand cycles in each gear. At 3 thousand, the accelerator pedal hardens and the speed does not increase. I watched it at 3 thousand cycles for half an hour, nothing changed. The fuel filter has just changed. 2 thousand km has only traveled. If it were a turbo, I think it would not go up to 3 thousand revs in each gear. Because I was out of town, I didn't want to show it to an ordinary master. Based on your knowledge and experience, I await your help. Thanks in advance
13.11.2020 09:19 # 2
Generally, the reason for this problem is my teacher, the turbo electrovalve or the tear in the hoses of this part.
13.11.2020 11:57 # 3
cimariva
Thank you very much. I'm out of town, now I need to find a good master and take it away When I did a physical check myself, I couldn't see anything. Well, would it be sufficient if this solenoid valve was cleaned and reattached?
13.11.2020 12:51 # 4
unfortunately my teacher. https://www.citroenmarket.net/urun/peugeot-307-1-6-hdi-turbo-elektrovanasi- this is the original part
13.11.2020 13:23 # 5
cimariva
Thank you for your help
25.11.2020 11:03 # 6
cimariva
Hello today I took it to my master and he connected it to the computer and looked. The problem is with the solenoid valve. Flow rate is excessive. I believe that there is no obstacle to use, and I continue by deleting the fault code because my time is limited, as there is no problem. Thank you to everyone.
