deleted
08.05.2020 18:06 # 1
awanger33
2005 FOR MAKEUP WITHOUT MAKE-UP
4 I WANT TO INSTALL THE BAS SPEAKER ON THE DOOR WHAT SHOULD BE WHAT IT SHOULD TAKE ATTENTION TO WHAT EXTRA TAKES
MATERIALS IN HAND:
DUBLE RELIGION PIONER
ANFİ PİONEER
WOOFER PIONER
awanger33 2014-03-20 10:18:07
08.05.2020 18:06 # 2
oguzhan29
My brother has his amplifier, if you want to have a nice installation, there are components for 4 doors on the component al jbl 608 or 508 oguzhan29 2013-11-29 22:11:31
08.05.2020 18:06 # 3
awanger33
You are right, I do not know how many centimeters fit it. I think it would not be nice to remove the cardboard boxes in the look.
08.05.2020 18:06 # 4
The front door is 16 cm.
Back door 13 cm.
08.05.2020 18:06 # 5
Alicilik
[QUOTE = 307bursa] [QUOTE = laedri] Front door 16 cm.
Back door 13 cm.
the dimensions are like this, but you may not get the efficiency you want from the powerful speaker that replaces the door speakers.
Can be boomed with a solid mid set of 16cm front and back
08.05.2020 18:06 # 6
barishrocker
The rear doors of the vehicle are 13cm..but the speakers are not mounted on the door plate but on the floor. It is also a problem for me. I put a double and put the original host in the torpedo so that the trip computer is not canceled. I had the mid team attached to the door sheet with a small modification. In addition, insulation was made inside the door. My vehicle has youtube videos. We got very good results ..
08.05.2020 18:06 # 7
error
[QUOTE = barishrocker] The rear doors of the vehicle are 13cm..but the speakers are not mounted on the door plate, but on the floor. It is also a problem for me. I put a double and put the original host in the torpedo so that the trip computer is not canceled. I had the mid team attached to the door sheet with a small modification. In addition, insulation was made inside the door. My vehicle has youtube videos. We got very good results .. [/ QUOTE]
listen to this man, you will not regret Big smile Maybe he does not remember, but I had a lot of help in making my car, the result was number ten. Clap Never isolate and rush it.
08.05.2020 18:06 # 8
barishrocker
[QUOTE = errör] [QUOTE = barishrocker] The rear doors of the vehicle are 13cm..but the speakers are mounted on the flooring and not on the door sheet..I also have the make-up of the same vehicle. I put a double and put the original host in the torpedo so that the trip computer is not canceled. I had the mid team attached to the door sheet with a small modification. In addition, insulation was made inside the door. My vehicle has youtube videos. We got very good results .. [/ QUOTE]
Thank you for your comment ... I'm glad you got a good result. Did you have a single door hb 307? barishrock is 2013-12-15 01:11:51
08.05.2020 18:06 # 9
EmSul
Do not touch the back doors at all, insulate the front doors and wear the Hertz esk-165 or Jbl power p6560 mid kit.
08.05.2020 18:06 # 10
barishrocker
[QUOTE = EmSul] Do not touch the back doors, insulate the front doors and fit the Hertz esk-165 or Jbl power p6560 mid kit.
What the friend says makes sense ... The system is more suitable with single coil 4ohm subwoofer alpine sbg1244br or focal 30a1, 4channel cadence xa 125.4 and alpine spg17.
08.05.2020 18:06 # 11
EmSul
The friend already has an amp and subwoofer!
08.05.2020 18:06 # 12
barishrocker
Then the amp and sub must give their features. Pioneer sub is probably double coil 350rms and it does not feed with 4 channels, it cuts the amp ..
08.05.2020 18:06 # 13
awanger33
thanks for comments and advice
I will not touch the doors for now, continue with the cabin bass: D
