defroster
08.05.2020 16:32 # 1
YUNNES37
friends, I am going to ask something inexperience.
& nbsp;
I press the button on the rear window resistor, it sounds like a click, but there is no button attached.
I don't get the mist of the rear window as well, where is the problem.
08.05.2020 16:32 # 2
Ali
The sound is the signal that the relay is working.
I think the reason for the lack of steam is that there is a break in the cables in the back.
08.05.2020 16:32 # 3
YUNNES37
Yes, there is a voice without roles. the button does not hold down. I wonder how my button is broken
08.05.2020 16:32 # 4
yavuz25
[QUOTE = YUNNES37] yes, there is a sound that plays. the button does not hold down. how can I tell if my button is faulty [/ QUOTE] The button is not faulty because
sounds. "Wink" If the break is in the glass, you have to take a liquid and repair it. If the break is at the connection points, it must be soldered. "Wink"
08.05.2020 16:32 # 5
06OzGuR06
If there is oxidation or disconnection, also check the resistance plugs. If there is oxidation in the plugs, clean and try again.
08.05.2020 16:32 # 6
yavuz25
[QUOTE = 06EZGÜR06] Check the resistance plugs if there is oxidation or disconnection. If there is oxidation in the plugs, clean and try again.
The vapor formed in the glass may have oxidized over time.
08.05.2020 16:32 # 7
cash1912
I have the same problem, I removed the joints on the rear window and cleaned them, but it did not happen again. Electricity is coming and made me look. Where can we find the liquid ...
08.05.2020 16:32 # 8
yavuz25
[QUOTE = cash1912] I have the same problem, I removed the joints on the rear window and cleaned them, but it did not happen again. electricity is coming. images / 803 / dsc00160be.jpg /
08.05.2020 16:32 # 9
cash1912
Thank you my friend. How is this application, we are just driving to the department with resistances.
08.05.2020 16:32 # 10
yavuz25
[QUOTE = cash1912] thank you my friend. How do we apply this is we just apply to the section with resistances. and it works. So it works. "Wink"
08.05.2020 16:32 # 11
06OzGuR06
[QUOTE = yavuz25] [QUOTE = cash1912] thank you friend. you mark it. You drive it and it installs. It works, so after all. "Wink"
Something nice & nbsp; this product "Clap" "Clap
08.05.2020 16:32 # 12
yavuz25
[QUOTE = 06ÖZGüR06] [QUOTE = yavuz25] [QUOTE = cash1912] thank you my friend. You identify the places that are broken and mark them. / QUOTE]
Good thing & nbsp; this product "Clap" "Clap
is really useful.
08.05.2020 16:32 # 13
What I know shouldn't be pressed anyway? right? & nbsp; It must be active once pressured and passive pressed once. When it is active, a light is on me.
08.05.2020 16:32 # 14
YUNNES37
I push the button & nbsp; button light & nbsp; is getting stronger but when I release the button, the light goes out.
said the electrician's button is broken, but the sound comes from the pressure.
I say I buy the button but 40 lira bidet went to the other button but 40 lira
08.05.2020 16:32 # 15
yavuz25
hold it down and test it, but don't say it might be damaged according to your system. "Wink"
08.05.2020 16:32 # 16
YUNNES37
Friends who have broken the role changed to the role.
08.05.2020 16:32 # 17
06OzGuR06
[QUOTE = YUNNES37] role broken friends changed to role, the problem is fixed. [/ QUOTE]
Get well ..
08.05.2020 16:32 # 18
yavuz25
Get well "Smile"
08.05.2020 16:32 # 19
ByHack
thanks for giving information on the subject again ...
