Deck Converter
08.05.2020 17:33 # 1
fexzi
I am setting up a new system. I want to learn from our experienced members that I will use the original headunit; & nbsp;
on the MA Audio deck converter; & nbsp;
green black
green red
< div> brown & nbsp;
orange colors my guess & nbsp;
green black (-)
green red (+) sounds like what others do you think would be glad if you help, picture available below.
08.05.2020 17:33 # 2
gozem
Normally there are 2 channel audio inputs and 2 amps outputs. they put a lot of cables in this model.
08.05.2020 17:33 # 3
qqyyxx
I made a nice modest system for 307 me and I couldn't share the picture upload because I couldn't do it. I was thinking of doing it with a deck converter, but I did my job with a high input level supported amplifier without using a deck converter + quality rca cable, & nbsp; it was the active subwoofer of the alpine I used, but a nice system can be made with a 200 TL mid-way amplifier. all you have to do is enter the cables to the rear speakers of the tape & nbsp; amplifier. amplifier only + - will be filmed & nbsp; some amplifiers are triggered from the auto speaker. For those who do not want to be triggered, I can describe the trigger output for rd 4.
08.05.2020 17:33 # 4
Alicilik
I had the same converter, but the colors were not the same. I gave it to a friend, he was using it very well.
Those connected to the speaker output;
White
White black
Gray
Gray black
Electricity and amp trigger;
Blue (amp trigger +)
black (chassis)
red (+)
Yours are a bit strange
Alicilik 2013-05-02 19 : 50: 09
08.05.2020 17:33 # 5
fexzi
Alim, I want you to say that the case is being disassembled, or if you can disassemble that case and take a photo of the cable bundle and show what color is in that bundle, I will tie the author in the same way.
08.05.2020 17:33 # 6
Alicilik
[QUOTE = fexzi] Alim, I want you, if the case is being removed or if you can disassemble that case and take a picture of the cable bundle and show what color it is in that bundle, I will tie the author in the same way. Believe me, I would take it off. Reviews
08.05.2020 17:33 # 7
fexzi
Good health then :)
