Daytime running light and led signal
08.05.2020 16:43 # 1
safrane23
Greetings friends. I opened the subject for daytime running light and additional signal led work. First of all, I write the necessary materials. 2 or 3 meter strip led, one silicon, one yellow glass paint, one gray spray paint. 4 meters double cable I smashed the old ethernet cable at home :)) total cost 10 TL. Then I painted the strip leds that I divided into 4 pieces with gray spray paint. Before painting, I wetted the paper so that the leds could not be painted, and I pressed lightly with the tip of the screwdriver to the place where the led was located, and I painted only the strips so that the leds would not be painted. The purpose was to grin inside the fog lamp, and after the paint dried, I placed the first strip led. There is a small round cover behind the fog lamp, I think there is a cover that prevents evaporation if there is any evaporation in it. I removed the end of the cable from there and closed the cover again. .I used ear litter here, just to touch it, it is enough to burn yellow. Finally, I glued the glass back with silicone again. And finished ones :)) I have the assembly next. I will connect the yellow ones directly to the signal bulb. I have a different idea for the connection of the daytime led. . safrane232012-04-21 21:29:12
08.05.2020 16:43 # 2
herry
I congratulate you, my friend, I have a nice job. enjoy it
08.05.2020 16:43 # 3
It was different. It is very successful. We are waiting for the photos.
08.05.2020 16:43 # 4
SZKR
I wish I found a reliable daddy to work in Izmit to 307 in Izmit.
08.05.2020 16:43 # 5
safrane23
[QUOTE = herry] buddy, congratulations on your good work, I am curiously waiting for your pictures on the vehicle. goodbye use [/ QUOTE]
thanks.
08.05.2020 16:43 # 6
safrane23
[QUOTE = koliva] It was different. It is very successful. We are waiting for the photos. [/ QUOTE]
thank you.
08.05.2020 16:43 # 7
safrane23
And its complete version ...
08.05.2020 16:43 # 8
herry
pretty nice, as if xenon =)
