Daytime running light and floating signal do not work.
08.05.2020 20:50 # 1
necmettinn
Hello again to everyone ... I said I couldn't take it when I saw the sliding signal I saw in some of the new generation vehicles and the daytime running light was on the famous site of those Chinese people. I decided to open it ... If you like, take a look at the video first. If you like it, I will wait for your comments .... https: //www.youtube.com/watch? v = S4L1vPOpH8oFirst of all I can say that it is a very simple process that everyone can do very easily. The link of the product https://tr.aliexpress.com/item/free-Kargo-Esnek-Ara-DRL-Ko-uDn-Sinyali-Beyaz-Amber-LED-Akan-Bar/32839476675.html?spm=a2g0s.9042311.0. 0.wuM5wwI bought it for $ 13 when I bought it but now it has the price of $ 14.07. When the product first arrived I tested it with an adapter at home, the image was satisfactory. There are three wires for its connection, the black one is (-), the red one is the white light (+) 12 volts, the yellow one is the signal (+) 12 volts. If the voltage comes to the yellow end while the white light is on, it turns off the white light and starts to light the yellow light as a signal. Let's come to the assembly stage ... Approach 1cm at the top of both headlights. there is a gap in the depth. The hood sheet closes on it, but it does not fill that gap. The incoming led strip is sitting right here. So there is no need to open the headlight glass. I attached it here with double-sided transparent tape. For signal connections we had to find the signal tip through the socket on the back of the headlight. The second ends from the top signal (+) 12 volt tip. I connected the yellow end of the incoming led strip here ... Right headlight Left headlight Socket structure Chassis connection ... I connected the black end of the led strip here ... And for the white daytime running light (+) 12 volts ... I found a tip connected to the contact from the fuse panel and got there I temporarily tied it up ... Of course, I made this link later and made it safe ... Veeeeeeee conclusion If you like to do or have it done, I try to help you where you hang out .... Everyone is safe and harmless days ......
08.05.2020 20:50 # 2
GiTaRRa42
I have seen this product, but you have attached it to the gap in the headlight as I understand from the photo. I do not have the correctness.
08.05.2020 20:50 # 3
necmettinn
[QUOTE = GiTaRRa42] I have seen this product, but I have a gap in the headlight that I understand from the photo, I do not have the correctness, I also have 206 such space, I want to try and share it to your useful hands ☺ [/ QUOTE]
Exactly, I adhered to that space with double-sided tape on the outside, hojam ... no need to open the headlight glass ...
NECMETT Tallinn 2018-04-14 01:32:29
08.05.2020 20:50 # 4
onlycihan
Thank you for sharing my health teacher. Can this product be shortened from the tip? Is it affected by rain from external factors and finally, every light is evident at night.
08.05.2020 20:50 # 5
boruc
Congratulations and nice work and nice expression.
I hope you will be satisfied using it
08.05.2020 20:50 # 6
necmettinn
[QUOTE = onlycihan] thank you for sharing my health teacher. Can this product be shortened from the tip? Is it affected by rain from external factors and finally, every light is evident at night.
There are 60cm lengths that I bought. Unfortunately, you cannot cut and shorten. Waterproof. Of course, it is not so clear at night that the more obvious fall. I upload the photos I took during the day and in the evening ... It may be necessary to mount it in the headlight or in a place where it can be seen more comfortably in the daytime ...
08.05.2020 20:50 # 7
necmettinn
[QUOTE = boruc] Congratulations on the nice work and nice expression.
Thanks...
08.05.2020 20:50 # 8
necmettinn
when the lamp is off
when the lamp is on
the signals are getting weaker ... but as I said, I think that the lamps can be replaced and alternative images can be obtained ...
08.05.2020 20:50 # 9
onlycihan
As I guess, they cannot give as much light as daytime. It will be more flashy to burn them from the time when the air will begin to turn dark with the logic of the park lamp.
08.05.2020 20:50 # 10
necmettinn
[QUOTE = onlycihan] As I guess, they can't give strong light during the daytime as night. It will be more flashy to burn them from the time when the air starts to turn dark with parking lamp logic.
In another video, they made a similar light over the bumper corner plastic. Maybe it can be put there ... I try to try it when it's available ...
08.05.2020 20:50 # 11
maximusti
bless your hands,
I was also thinking of installing it in the headlight from the same product I bought, I did not wear it because I could not open it.
You need an American park in your car :)
08.05.2020 20:50 # 12
necmettinn
[QUOTE = maximusti] good health,
I know that it is very troublesome to turn on the headlight .... starting from the bumper, to get the headlights to disassemble, the glass separation process (not only sticking with nails) is also a different effort .... I was planning to do it first, but I did not bother when the space above the headlight was sufficient. ... :)
