dating my partner car help me
08.05.2020 16:41 # 1
aopena
friends car pejo partner hdi engine and 2004 model was a small accident in my car last summer and the front radiator had changed now it is hotter since this radiator is the side industry. it is a little downhill slope, so it is going to be a lot of pressure in the future. At the same time, the LCD screen with the date and time on the front of this vehicle went out, however. thanks now
08.05.2020 16:41 # 2
[QUOTE = aopena] my friends car pejo partner hdi engine and 2004 model was a minor accident in my car last summer and the front radiator had changed now it is hotter because it is a side industry, it gets warmer in the weather when it starts to reach 80 when i start traveling with the vehicle, it turns out 90 The roads of our artvin are a little bumpy down the road, so it is going to be a lot of printing in the future. Can I find this radiator as a part of my car, the fan will turn on the fan as well as the fan when it turns 90, now it even opens it too late, yes friends can help me know Where do I find the radiator peo partner 2.0, and the LCD screen of this vehicle with the date and time on the front has gone out, however. Tests from now [/ QUOTE]
The 80% of your vehicle's temperature immediately shows that the radiator cannot have any function. Because the cooling water in your vehicle does not allow thermostation, it cannot reach the radiator in that degree. The aim is to reach the optimum working temperature as soon as possible and to keep it as stable as possible.
The failure of the fan has nothing to do with the radiator. Whether the fan is urgent or not will be determined by the information coming from the heat officer determines the brain of the vehicle. Moreover, there are two stage (two speed) fans in our vehicles. I guess you hear it when you are in the fan speed mode at 100 degrees because it is very difficult to hear the sound of the fan working at low speed.
Of course, you know, but if your vehicle cannot drop to 90s when the fan is running at 100 degrees, then you should look for a problem in the radiator. Reviews
08.05.2020 16:41 # 3
aopena
But there is such a thing as this vehicle 2.0 hdi engine turbo, that is 90 years ago, if we force it very hard, it has been 3 times a year for 90 years, it has reached 90 times at most 3 times. As you said, it would have reached 80, okay but it wouldn't pass even one mile and I tested it, knowing that I was able to press the full speed gas and heat it, even I passed 100 years ago. If so, if it is okay, exactly where do I look at your muse so let me have them look where the problem is, tell me exactly where is it or this vehicle seems like a high engine
