dating fan problem help.
08.05.2020 16:19 # 1
ispanyol2
& Nbsp; & nbsp; & nbsp; & nbsp; & nbsp; Hello dear masters and friends, I would like your help on a subject.
& nbsp; & nbsp; The problem of my 2002 model 1.9 air-conditioned partner vehicle: I run the car, while the fan button on the console is in the off position, while the heater & nbsp; fan is constantly running, the vehicle never stops until the vehicle stops, and we have reached the back of the button and unplug the socket from the button and it continues to work without interruption again. As far as I learned, they say that there is a heating module and it works continuously since it is broken. it sounds right in logic but we couldn't find where the module was, even though we searched so much to check.
I would like to ask you how we find this heater module in the vehicle. respects
08.05.2020 16:19 # 2
ispanyol2
Dear admin, in this forum, we don't have a master who understands the partner.
Regards
08.05.2020 16:19 # 3
peugeotefe
At which level does the heating engine work?
08.05.2020 16:19 # 4
Dear Spanish Will Help You With Information About The Topic ..
Nobody Will Help You Or You Will Have To Go To The Service ....
08.05.2020 16:19 # 5
ispanyol2
the last stage is working, it decreases a bit when I plug and turn the cable connection socket of the adjustment knob on the console, but it works continuously at the last cycle if I remove it. It is certain that the
problem is in the module, but where the module did not find it, I followed the cables and there is nothing visible. I just need a place where I can do the rest and I can handle it easily.
regards
08.05.2020 16:19 # 6
peugeotefe
If your vehicle is air conditioned without air conditioning, the module is on the fan motor.
08.05.2020 16:19 # 7
ispanyol2
Thanks, Mr. Efe, the passenger side, which seems to be air conditioned, will enter from below.
respects
08.05.2020 16:19 # 8
peugeotefe
Pardon you have already written that it is air conditioned. There is a resistance inside the fan motor, that part in the form of aluminum has failed.
08.05.2020 16:19 # 9
Baybars
Cihan usta & nbsp;
