date model setting 1.4 petrol 2003 model
08.05.2020 21:02 # 1
Ashraf16
Hello friends.
I have a 2003 model 1.4 x-line petrol 206.
I could not change the date and time setting on the screen.
In his booklet, he writes that the button on the left side is pressed for 7-8 seconds and is feasible.
But it is not like that.
I would like you to help my friends who have knowledge or experience.Thank you
08.05.2020 21:02 # 2
talip206
First you need to long press the left button. Long press the language comes out, for example, it says english. (Flashes) Then take your hand off the left button and then briefly press the left button to switch to the date and time setting. Adjustment is also made with the right button. talip206 2018-10-12 22:01:46
08.05.2020 21:02 # 3
Ashraf16
I tried very, very hard. Pressing the left button on the indicator glass, where the speed and tachometer is located, flashes english on the date clock screen on the middle panel of the tape, and other languages appear when you press the left button on the middle panel. I could not adjust because the date or time figures were not flashing.
08.05.2020 21:02 # 4
talip206
[QUOTE = Ashraf16] I tried too much. I couldn't. Pressing the left button on the indicator glass, where the speed and tachometer is located, flashes english on the date clock screen on the middle panel of the tape, and other languages appear when you press the left button on the middle panel. I could not adjust because there was no flashing on date or time figures [/ QUOTE]
You will not do it from the display section, but from the keys at the top of the screen in the middle. First press the left one for 2 3 seconds, then briefly press it.
By the way is the tape the original tape
talip206 2018-10-15 16:51:40
08.05.2020 21:02 # 5
Ashraf16
Tape is not original. I tried that way too many times. Nothing happens when I hold it flat. Now I suspect that your key is broken
08.05.2020 21:02 # 6
talip206
I know that the time and date cannot be adjusted when the tape is not original.
08.05.2020 21:02 # 7
doganatak
[QUOTE = talip206] I know that the time and date cannot be set when the tape is not original. [/ QUOTE]
Setting can be done on my tape, not the original, I changed the battery last date was broken. We adjusted again. Probably has another problem
08.05.2020 21:02 # 8
Ashraf16
I wonder if I remove the battery and plug it in again. But would all the brain settings deteriorate. When the battery is disconnected
