dashboard
08.05.2020 14:01 # 1
Hello friends, my car is a 2001 model 206 xr.
08.05.2020 14:01 # 2
sinan-s
It may be ABS light. Hashim brother gives you clear answer when you see the subject
08.05.2020 14:01 # 3
MirakGTI
I know that light in rainy hawa
08.05.2020 14:01 # 4
hasimayaz
I think you're talking about the lamp that represents a vehicle that slides in the triangle:
Dynamic Balance Control Warning Lamp (ASR / ESP)
Illuminates for a few seconds each time the ignition is switched on. When the engine is running, the indicator lamp flashes when the system is activated while the vehicle is in motion. When disabled, it remains lit with a message on the multifunction display. If this indicator lamp stays on while the engine is running, the problem should be detected by connecting the ram to the computer.
08.05.2020 14:01 # 5
hasimayaz
1. Unfastened belt indicator lamp
2. Passenger Airbag deactivation indicator lamp
3. Airbag indicator lamp
4. Front fog lights indicator lamp
5. Wheel anti-lock system (ABS) indicator light
6. Rear fog lamp indicator light
7. Diesel engine preheat indicator lamp
8. Left signal
9. Total odometer, maintenance indicator, engine oil level indicator and cruise control / limiter
10. Right signal
11. Air pollution prevention system indicator lamp
12. Main beam warning lamp
13. Parking brake, brake fluid level and EFD malfunction indicator lamp
14. Dipped beam indicator lamp
15. Battery charge indicator
16. Engine oil pressure and temperature indicator lamp
17. Engine oil temperature indicator
18. Total odometer button
19. Central alarm warning lamp (STOP)
20. Speedometer
21. Coolant temperature indicator
22. Cycle counter
23. Lighting dimmer button
24. Fuel level indicator
25. Fuel minimum level indicator light
26. Dynamic balance control (ESP / ASR) indicator lamp
27. Cruise control / limiter indicator lamp
08.05.2020 14:01 # 6
hasimayaz
7. Left signal
8. Total odometer, maintenance indicator, engine oil level indicator and cruise control / limiter
9. Right signal
10. Air pollution prevention system indicator lamp
11. Main beam indicator lamp
12. Parking brake, brake fluid level and EFD malfunction warning lamp
13. Dipped beam indicator lamp
14. Battery charge indicator lamp
15. Engine oil pressure and temperature warning lamp
16. Work programs
17. Gearbox position indicator
20. Speedometer
22. Cycle counter
08.05.2020 14:01 # 7
hasimayaz
1. Unworn belt indicator
lamp *
2. Disabling Passenger Airbag
indicator lamp *
3. Front and side Airbag indicator
lambas¤
5. ABS: Preventing wheel lock
6. Rear fog indicator lamp
7. Left signal
indicator and engine oil level
indicator.
9. Right signal
10. Engine auto diagnostic display
lamp
12. Parking brake, brake hydraulic oil level
and EFD fault warning lamp
13. Low beam indicator lamp
lamp
16. Coolant minimum level and
overheat indicator lamp
17. Study programs
18. Gearbox position indicator
19. Total odometer button
20. Central alarm warning lamp
(STOP)
21. Speedometer
22. Coolant temperature indicator
23. Cycle counter
24. Lighting dimmer button
25. Fuel level indicator
26. Fuel minimum level indicator
lamp
* By country
08.05.2020 14:01 # 8
sinan-s
Maşallah, hasim
08.05.2020 14:01 # 9
<bugra>
hey maşallah :)
That's the answer, health to your hand ...
08.05.2020 14:01 # 10
hasimayaz
It is the same job, the person does not look at the word, in the visible rank-mind of the person .. Wink
08.05.2020 14:01 # 11
<bugra>
the issue is to avoid pollution;
Air conditioner - central heating control panel lights went out.
I dismantled all the bulbs burst, can I change the color by connecting the sequential white led?
08.05.2020 14:01 # 12
hasimayaz
[QUOTE = ] subject to avoid pollution;
the transparent material of the panel illumination is yellow and even at some points red. In other words, whatever light you give from below will light up in the shades of these 2 colors. You may not get the performance you want in the lighting as the led bulb gives a single beam of light. So a wavy glow can wait for you.
I changed the bottomless bulbs with blue led to change the clock color. I gave up on this love, as it turned out to be a purplish color.
Here is the infamous color:
08.05.2020 14:01 # 13
entel
Thanks for your nice sharing, Haşimayaz ..
The friend who asked the question was not satisfied because he did not even thank him.
08.05.2020 14:01 # 14
<bugra>
where I was talking about the illumination of the buttons under the tape
but the color will be the same again ...
2009-01-11 14:33:03
08.05.2020 14:01 # 15
hasimayaz
[QUOTE = ] where I was talking about the illumination of the buttons under the tape
The material is the same steam. I tested it on the center console and instrument panel as well .. the transparent material is yellow. No matter what color it is burning, it is printed on yellow.
hasimayaz 2009-01-11 14:40:03
08.05.2020 14:01 # 16
koraycan
friends, I met 206 hdi in 2004, I had a very big accident, my nose couldn't even bleed, we got head to head with e200 mercedes, I got zero 206 hdi again in 2006, because my enthusiasm is not over, I bought the feline model is the most fully equipped ... citroen with multijet and hdi motor in our company nemo is available, hdi engine is definitely better than multijet and very long-lasting, I know my car very well at its 206im 70 thousand.It is generally enjoyable cars for those who use fiat or opel in general, all the questions about diesel 206. I can answer, I am waiting for all kinds of questions until the tire brand oil brand I will recommend.
08.05.2020 14:01 # 17
<bugra>
[QUOTE = hasimayaz] [QUOTE = ] where I was talking about the illumination of the buttons under the tape
I disassembled the original bulbs, I did not try white first, then the red led string was tied up
it was a very nice image ...
I want to do the same for the dashboard, but the recipe etc. Is there a subject that is happening?
Thanks...
08.05.2020 14:01 # 18
hasimayaz
Picture 1 You pull the piece 4 out of your nails by pulling it towards you with your hand. (starting to pull from the top)
Picture 2 you will unscrew the screw number 70 and pull the panel towards you. You should pay attention to the kilometer wire and cables from behind. You don't need to unplug these cables. After separating enough to enter the hand, you should see bottomless bulbs from behind. You can replace them with your hook-up
08.05.2020 14:01 # 19
friends on my dashboard the km hand hangs at 0 and strangles the engine what do you think is the problem.
08.05.2020 14:01 # 20
EMRE
[QUOTE = enyl]
http://forum.peugeotturkey.com/forum_topics.asp?fıd=22
If you introduce yourself first, you will get help on the site.
Page : / 3
