Dashboard
08.05.2020 19:31 # 1
swordtolga
Hello, all the lights on the indicator are on as you go, what could be the reason?
08.05.2020 19:31 # 2
talip206
If all of them went away, I would say that there is contactlessness. But suddenly all of them flash and then go out may be related to the brain. But first, how is the condition of the battery, is the voltage appropriate? Except original, xenon headlight, installation etc. are there anything you need to know them. If everything is original, there may be problems in the brain.
08.05.2020 19:31 # 3
swordtolga
[QUOTE = talip206] I would say there is no contact if they all go away. But first, how is the condition of the battery, is the voltage appropriate? Except original, xenon headlight, installation etc. are there anything you need to know them. If everything is original, there may be a problem in the brain. [/ QUOTE]
especially when maneuvering, all the lights are on, just like during the first start up, it turns on for 1 second and goes right away when you say the brain? battery new battery
08.05.2020 19:31 # 4
xmen
Is the vehicle scuba
08.05.2020 19:31 # 5
swordtolga
[QUOTE = xmen] Is the vehicle scuba [/ QUOTE]
vehicle gasoline tube never installed
08.05.2020 19:31 # 6
Cyrus35
Dude I suspect the com2000 unit as if there was some contact when turning the steering wheel. Or can it be a plug-in interior lighting or a line drawn from there?
08.05.2020 19:31 # 7
swordtolga
[QUOTE = Cyrus35] Dude I suspect the com2000 unit as if there was a contact when turning the steering wheel. Or can it be a plug-in interior lighting or a line drawn from there? [/ QUOTE]
I had a sound system connected to the car a week ago, but it was before that. For example, think about it.
08.05.2020 19:31 # 8
xmen
Sir, it may be irrelevant, but the vehicle will stop and start again, the indicator lights are on at the moment
08.05.2020 19:31 # 9
swordtolga
[QUOTE = xmen] My teacher may be irrelevant, but the vehicle will probably stop and start again, the indicator lights are on at the moment [/ QUOTE]
the vehicle's gas pump and float are defective. because he's cutting gas?
08.05.2020 19:31 # 10
swordtolga
08.05.2020 19:31 # 11
Tolga can, after all, stop immediately because gasoline is interrupted for an instant.
