Dashboard
08.05.2020 17:02 # 1
sosyete_60
friends 1.6 16v 2001 model 206 has a sluggish problem on the road while the speed indicator is working at the moment, when it does not work at the moment, the car goes awkward, & nbsp; trembling occurs, but when the screen improves, the car goes on a regular basis. They said it was not, but when they made the breakdown, they said we could understand it.
08.05.2020 17:02 # 2
mustigiz
merhaba,
the same error was & nbsp; in my vehicle.
speed sensor malfunctioned, < / div> Didn't the speed sensor alert on the
diagnostic tool?
when this fault occurs, the vehicle is going to be ridiculous, as if 4 tires are independent of each other, etc. ..
is a then stacked and sudden forward and backward etc..vs ..
if your fault is like this, look at the speed indicator,
& nbsp;
track 80-85 tl and so I guess ...
& nbsp;
& nbsp;
regards.
08.05.2020 17:02 # 3
sosyete_60
Yes, exactly, my brother is detecting the car, but why did not he give this error? I would be glad if you knew me exactly where the car was, the sensor was working when I entered the service.
08.05.2020 17:02 # 4
mustigiz
selam,
this is the piece; There was a gear on the end of it, I think your gear is there somewhere.
& nbsp;
08.05.2020 17:02 # 5
mustigiz
I did not know how the bottom gear is in honda, peugeot.
08.05.2020 17:02 # 6
sosyete_60
thank you very much my friend, i am grateful to you, this is the other name of the kilometer gear.
08.05.2020 17:02 # 7
mustigiz
What is the cost of injector cleaning when you go? and how many hours of operation can you ask?
& nbsp;
thanks.
08.05.2020 17:02 # 8
sosyete_60
okay let's ask my brother
08.05.2020 17:02 # 9
sosyete_60
this problem was possible with the gearbox, the gearbox was dismantled and then started to do it
08.05.2020 17:02 # 10
mustigiz
of course
& nbsp;
or did they forget to plug in the sensor :)
08.05.2020 17:02 # 11
sosyete_60
No transmission was done 3 months ago, it started to be done in the last 1 month & nbsp; did not do anything after doing & nbsp;
08.05.2020 17:02 # 12
It seemed like an electrical problem to me. There may be a lack of contact at the connection points of a sensor on the transmission side. Unplug the plugs you can reach with your hands and see if there will be a correction.
08.05.2020 17:02 # 13
sosyete_60
ok they will look at the evening today
08.05.2020 17:02 # 14
ekinoks44
They said the transmission could be the same problem with me. In fact, when the km counter does not work, the airbag light turns on for 10 seconds & nbsp; then it gives an audible warning. This warning does not exist when it works.
