daily km fault (SOLVED)
08.05.2020 13:57 # 1
TOLGA
friends I reset the daily km of my car and it has not progressed any more, it remains as 00000 Unhappy
Where can I have it repaired and what does it cost? anybody have an idea?
ADRENALIN 2008-11-04 20:53:16
08.05.2020 13:57 # 2
hasimayaz
Have the battery terminals removed and installed (not on the ignition key)
What is a vehicle ?? is the watch mechanical ?? is it digital?
hasimayaz 2008-09-18 22:11:14
08.05.2020 13:57 # 3
sinan-s
Well, I work hours .. So the pointer ..
08.05.2020 13:57 # 4
What is the vehicle brand model?
digital or analog?
08.05.2020 13:57 # 5
never mind, don't write kilometers Tongue
08.05.2020 13:57 # 6
sinan-s
Vehicle 106 XR 4 doors
analog instrument panel
08.05.2020 13:57 # 7
reform service
08.05.2020 13:57 # 8
TOLGA
[QUOTE = sinan-s] Vehicle 106 XR 4 doors
exactly
08.05.2020 13:57 # 9
TOLGA
[QUOTE = sinan-s] well clock work..so the pointer .. [/ QUOTE]
ewet speedometer works, main km also works, not just the daily one,
I did not remove the pole heads, would it be okay if I disassemble it?
08.05.2020 13:57 # 10
hasimayaz
If it is analog, it will not improve .. most likely there is a break in the nails .. a fine job .. if you can find a way out so entry .. or touch it ..
08.05.2020 13:57 # 11
TOLGA
[QUOTE = hasimayaz] If it is analog, it will not be improved .. most likely there is a break in the nails .. if you can find a fine job .. you can find such input .. or touch it .. [/ QUOTE]
I have to replace my complete front instrument panel if I find dating?
ADRENALIN 2008-09-19 12:04:38
08.05.2020 13:57 # 12
hasimayaz
[QUOTE = ADRENALINE] [QUOTE = hasimayaz] If it is analog, it will not improve .. most likely there is a break in the nails .. fine work .. if you can find a way out, do not touch it .. or touch it .. [/ QUOTE]
If you find its assembly, it is more desirable. Otherwise, you will have to completely dismantle the dashboard and change the counter through it .. a very complicated job .. you should not harm the hand mechanisms.
08.05.2020 13:57 # 13
sinan-s
Get well soon..
08.05.2020 13:57 # 14
TOLGA
[QUOTE = sinan-s] get past .. [/ QUOTE]
thanks sinan
08.05.2020 13:57 # 15
TOLGA
[QUOTE = hasimayaz] [QUOTE = ADRENALINE] [QUOTE = hasimayaz] If it is analog, it will not improve .. most likely there is a break in the nails .. a fine job .. if you can find a way out, so input .. or touch it .. [/ QUOTE]
thank you for the information Wink
08.05.2020 13:57 # 16
TOLGA
[QUOTE = 306TT] reform service [/ QUOTE]
Free What do you say? Is it possible to solve this job at a reasonable price in the reform?
08.05.2020 13:57 # 17
[QUOTE = ADRENALINE] [QUOTE = 306TT] reform service [/ QUOTE]
tolga brother I think if you take it to the mileage, you should have an old order counter like yours is not digital ... I think a wire etc. has come out.
08.05.2020 13:57 # 18
TOLGA
[QUOTE = 306TT] [QUOTE = ADRENALINE] [QUOTE = 306TT] reform service [/ QUOTE]
Thank you,
If I cannot handle it, we will contact,
08.05.2020 13:57 # 19
every zmann brother
08.05.2020 13:57 # 20
TOLGA
the problem has been solved friends, we have seen it, we've looked, we've seen it, but said it was not a defective situation, my master and just put it back and started working :)
Page : / 2
