cylinder head oil leak 307
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 19:02 # 1
emresensoy307
My friends went to ask the authorized service of my vehicle this day, the friend of the minister said, there is an oil leak from your cylinder head, one at the top. There was a gasket, he told me between 400 and 500, he said to me, then a friend has a master, we asked him, the room was between 200-250, the price faded, do you think how was my car trembling with gear changes?
08.05.2020 19:02 # 2
muro_60
it has nothing to do with kicking, but it does not make a lot of the cylinder cover.
08.05.2020 19:02 # 3
dogan
I had a problem with me in the industry. After 1 month, I looked next to him two days ago and there is a kidnapping.
I love my car 307 very comfortable beautiful car but it is obvious when it is very problematic.
If you do somebody else it breaks out somewhere else, the psychology of the real estate is broken
08.05.2020 19:02 # 4
muro_60
[QUOTE = born] I had a problem with me, I had it done 1 month ago in the industry. After 1 month, I looked next to him two days ago and there is a kidnapping.
[/ QUOTE] only because the master equipment is bad so there is no problem in the vehicles
08.05.2020 19:02 # 5
emresensoy307
Now I do not know exactly where you missed it, but the upper one said that the upper part of the cylinder from the cylinder cover, the oil said very little, the master said, 400-500, the master outside, 200- 250, said the material does not reduce the oil to the original vehicle ...
08.05.2020 19:02 # 6
muro_60
[QUOTE = pug206emre] I do not know exactly where he missed now, but he said the upper body was too low from the cylinder head in the service, the master said it holds 400-500, the master outside holds between 200- 250, the material does not reduce the oil on the original vehicle ... [/ QUOTE] I wrote the price, it would be better if you have it washed already.
08.05.2020 19:02 # 7
emresensoy307
The timing has changed before, this is a big problem of leaking oil.
08.05.2020 19:02 # 8
emresensoy307
guncel
08.05.2020 19:02 # 9
emresensoy307
guncel
08.05.2020 19:02 # 10
muro_60
[QUOTE = pug206emre] The timing has changed before, this oil leaking is a big problem. If there is a leakage of oil, it means there is a mistake. It will be a problem in the future.
