cylinder head gasket and upper lid gasket picture |
| • Homepage » PEUGEOT MODIFIED PLATFORM » 307 | |
| 08.05.2020 19:11 | # 1 |
| 08.05.2020 19:11 | # 2 |
tetik-soner |
Get well soon...
| 08.05.2020 19:11 | # 3 |
guncel
| 08.05.2020 19:11 | # 4 |
friends up to date
| 08.05.2020 19:11 | # 5 |
If there is not much leg, I don't think it should be handled. The master said it would not hurt either. If you don't seriously reduce fat,
| 08.05.2020 19:11 | # 6 |
a little oil is missing, but if this is not the case, it will change in the future, I wonder what it will cost ..
| 08.05.2020 19:11 | # 7 |
Cylindrical cap revision is already 16v intermediate engine is between 500 .... 600 I think it will be hot in the future and risk taking circlip piston and the rice in the house is always good;) 0209.fl 0807.33 0807.35 0249.c6 2 antifreeze suction name gasket changes
| 08.05.2020 19:11 | # 8 |
I have the same problem, the gasket and the cylinder head gasket are greasing oil.
| 08.05.2020 19:11 | # 9 |
Then, the price given by the authorized service is normal, but there are these tightening values.
| 08.05.2020 19:11 | # 10 |
A current ..
| 08.05.2020 19:11 | # 11 |
Is the teacher on the upper side from the screws on the black engine cover?
| 08.05.2020 19:11 | # 12 |
There is no such thing as screw o Sent valve valves in old models such as 106 v, p. Your mind will be revised cover
| 08.05.2020 19:11 | # 13 |
Uskulubutor gaskets change, only the same thing happened with me.
| 08.05.2020 19:11 | # 14 |
My brother Emre is 2 months old 206 sw 2005 gasoline vehicle. my first car. I hardly understand, I bought it with reference. the plastic box where I put the water in my vehicle it was filled with a slimy substance. As a result, they said that the oil is mixed with water , and we removed it up to the engine top cover gasket, I bought the gasket for 40 TL. I gave 150 TL of labor. and additive for mixing into water I bought 35 TL to clean the institutions in the system. There is no problem right now. If I can upload photos, my vehicle is in the middle. thank goodness has improved. |
| 08.05.2020 19:11 | # 15 |
I do not fully understand my brother, but I will upload your picture and talk more clearly ...
| 08.05.2020 19:11 | # 16 |
| 08.05.2020 19:11 | # 17 |
| 08.05.2020 19:11 | # 18 |
| 08.05.2020 19:11 | # 19 |
| 08.05.2020 19:11 | # 20 |
the top picture is the top cap, the bottom one is the cylinder head
