Cylinder head gasket
08.05.2020 20:50 # 1
Gboz3510
Hello friends, I need to change the cylinder head gasket 1.6 VTI urgently.
08.05.2020 20:50 # 2
Gboz3510
I bought the price from somewhere, it will not be lower than 2000 TL
08.05.2020 20:50 # 3
Orcun.Dmr
There are many people who recommend the 6th Industry Happy Auto in the forum. If you want, I would go and get a price.
08.05.2020 20:50 # 4
Gboz3510
Okay thanks
08.05.2020 20:50 # 5
GokhaN
[QUOTE = Gboz3510] I got a price from somewhere said it would not be lower than 2000 TL [/ QUOTE]
everybody is processing that you can get it, you need to handle around 1000
08.05.2020 20:50 # 6
To get past 2000 TL, 1000-1500 TL should be resolved.
08.05.2020 20:50 # 7
Gboz3510
they said to me at least 2000 or possibly 2500 TL.
08.05.2020 20:50 # 8
Gboz3510
But there is a situation like this: I went to someone who is famous in the industry. . I researched this brain reset we can do it ourselves but a little bit confused
08.05.2020 20:50 # 9
a master who has done a compression test will be better if you find a good sound engineer.
08.05.2020 20:50 # 10
ismailkaya
Take it to the service, negotiate with friends, they can give a better price than this market.
08.05.2020 20:50 # 11
Gboz3510
These tools are not compatible with the tube, but many use the tube. The lpg system is not a poor system
08.05.2020 20:50 # 12
[QUOTE = Gboz3510] these tools are said to be not fully compatible with the tube, but many use the tube. The lpg system is not a poor system, too [/ QUOTE]
I have a lot of brothers who use the right tube, but first it must be a good assembly, so I knew these engines in time and researched them. I read. Prins brother is usually the most compatible with our vehicles. Later, those who use it without problems, such as brc-landirenzo etc. But workmanship is very important in this regard.
