Cyclical rides ...........
08.05.2020 15:11 # 1
boraa
How to drive the vehicle, what are the driving techniques in our vehicles. What are the benefits of driving? I expect information from the masters. Thank you. Handshake
08.05.2020 15:11 # 2
Muhammet CAKIR
bro, I guess your vehicle is already automatic :)) but normal gear change cycle in 2,500 rpm diesel vehicles :))
08.05.2020 15:11 # 3
boraa
I understood ... then let's hit the gas and let's go to D ...
08.05.2020 15:11 # 4
Unfortunately, you do not have a chance to cycle automatically.
08.05.2020 15:11 # 5
byu01
In automatic geared cars, it is necessary to take your foot off the gas in the gear change interval and press the gas again.
08.05.2020 15:11 # 6
boraa
I just heard this information, brother. Alkış
08.05.2020 15:11 # 7
C!N
Dude, if you want to cycle, the `` S '' button will be pressed, your foot will make the bottom gas as much as possible, the rest of the gearbox will adjust. But then come and don't cry around here because my car burns very much SırıtmaSırıtmaKahkahaSırıtmaSırıtma
Sırıtma
08.05.2020 15:11 # 8
[QUOTE = C! N] Dude if you want to cycle, the `` S '' button will be pressed, your foot will make the bottom gas as much as possible, the rest of the gearbox will adjust. But then come and don't cry around here because my car burns very much SırıtmaSırıtmaKahkahaSırıtmaSırıtma
Sırıtma [/ QUOTE]
yes it is very short and oz :))
08.05.2020 15:11 # 9
dogu
Do not waste in new generation vehicles, both your car will burn very much and your safety will be in trouble. When you take your foot out of the gas in the gear, the car is 0 lit.
08.05.2020 15:11 # 10
boraa
As far as I know in automatic transmissions, there is no wasting event, right? Shocked
08.05.2020 15:11 # 11
The reason why it is not thrown into the boot when going through automatic gearboxes is that it does not lubricate when thrown into the boot. when it is fully emphasized, it can be bought.
08.05.2020 15:11 # 12
boraa
I understand that there is no such thing as using automatic brakes in auto vehicles. Or is there a situation that we should not pull our feet from the gas unless we are in a difficult position. Shocked I heard such a thing.
08.05.2020 15:11 # 13
[QUOTE = boraa] I understand master, is there a situation in automatic vehicles that there should be no use of brakes. Shocked I heard something like that. What a relevance! [/ QUOTE]
Allah Allah, I have never heard so crazy, so :))) What will you stop when you don't use the brakes? By praying ?? :))) I couldn't understand what the parsley was :) :) I guess they made you a joke. If you don't need it already, don't you brake? In addition to the stop you will print in the instant of your need ...
08.05.2020 15:11 # 14
dogu
Gülme
08.05.2020 15:11 # 15
This is the best thing to pull the handbrake removed with 160 and press the gas and brake at the same time :))
08.05.2020 15:11 # 16
BAHTIYAR
I don't know the gearbox of the 206, but my car has a manual mode that is possible to use revolutions + the uphill and downhill gear does not grow up, so when you go out, the engine takes advantage of compression / automatically climb to the hill as high as possible, so that the car does not have to change gear on the slope, do not take it in the course of the uphill. Do not leave the car in grip so that the transmission is long lasting and good evening everyone
08.05.2020 15:11 # 17
C!N
Dude, you have misinformed you, you use more brakes in automatic gear vehicles than manul, because you can use the engine compression is more limited than manual gear vehicles, which is why the brake pads run out more quickly in automatic gear vehicles (I changed my pads on the vehicle at 20 thousand km). for example). You can also take your foot out of the gas whenever you want.
08.05.2020 15:11 # 18
boraa
In one of my questions, my master will say: `` It is better to go in D mode when stepping uphill on automatic cars, or it is better to take triton and go up at 1.2 gears. Confused Um, if I get stuck, I throw it into 2nd gear. The vehicle doesn't get lost. When it goes straight, I switch to D mode. I don't want to leave it to chance. they said it was okay to take it to the service ... can you give me information about this subject
08.05.2020 15:11 # 19
dukenukem82
[QUOTE = mustafakirli] It's best to pull the handbrake removed with 160 and press the gas and brake at the same time.))) [/ QUOTE]
Embarrassed super Sırıtma
08.05.2020 15:11 # 20
dukenukem82
the right steep slope you make does not come out with d
Page : / 2
