cutting fiberglass ...?
08.05.2020 20:11 # 1
dejawu1978
hi aleyküm .. beyler you ordered double din from china 10 days ago suan TR logged in the product reaches to c.
the product is not very high quality, but as if it is managed according to the money, I also bought this product especially the back part is short, i.e. it is like 5cm.
I got a spare one on the front console and bought a spare one on the front console. 1 month ago, the main problem is 75 TL. Here I came to the place where the zurnan said to be honest. I am waiting for your ideas and suggestions that I have been doing such a work before ...
Thank you to friends who already comment ...
this on the console
08.05.2020 20:11 # 2
KILIC
Well, I don't know how you can topram, but he knows the job on aliexpress.
08.05.2020 20:11 # 3
dejawu1978
I will take the thinnest tooth saw in my hand, I will go from small to small, of course, I don't know what happens next until I get into it. dejawu1978 2017-02-15 18:55:57
08.05.2020 20:11 # 4
BLACK LION
dejawu1978 If you normally say that I will cut it, that double does not seem to fit there, this kind of work is cut with spiral. When it goes down to the bottom, there is not much place to hold, but you know. I think it would be more accurate to get the tape from the screen.
08.05.2020 20:11 # 5
dejawu1978
Well, double din did not get my hands until that time, I said, let's do a little study.
As you said from the bottom and the top, there is not enough room to hold it so firmly, but I do not think that there will be a weight of 5.5 cm behind the back, by mounting it on the right and supporting it from left to right, not like normal double religions.
08.05.2020 20:11 # 6
KILIC
When I looked at the appropriate frames for 206, the double religion would be almost $ 300 for the price, yaw. Actually, if you have molded, can't you do it in industry?
08.05.2020 20:11 # 7
dejawu1978
[QUOTE = KILIÇ] When I look at the appropriate frames for 206, the double religion is almost 300 TL for the price, yaw. If you actually molded, you can't do it in industry [/ QUOTE]
I would like to find a product to match each other in 2 sins. Big smile
08.05.2020 20:11 # 8
samet206
You can cut the plastic panel with a heated brush or knife. I used this method for similar works before. But then sandpaper or paint may be required. This home-style course is evaluated if you have more professional tools. If it comes with the product cage and edge frame, your job will be easy. You screw the sides from the sides so that the cage does not appear when you sit in the chest and place the double.
08.05.2020 20:11 # 9
onlycihan
there is also a heated knife, but it is easier. Remove the mold using iron bars on the outer frame dimensions. You can also melt the interior parts with a soldering device. In the meantime, to use the iron soldering device straight.
08.05.2020 20:11 # 10
dejawu1978
The risk of deforming the solid side of the product in heated cuts is very gentle to do gently with a bristle saw, I am already a café.
I have this product, I already have this kind of work
dejawu1978 2017-02-16 15:18:16
08.05.2020 20:11 # 11
the best thing is to buy such a machine
08.05.2020 20:11 # 12
KILIC
[QUOTE = dejawu1978] The risk of deforming the solid side of the product in heated cuts is the most robust hair saw gently.
I have internet cafe, where is the place?
08.05.2020 20:11 # 13
samet206
I cut the torpedo by heating, and the advantage for me is that it can be cut without notice, wherever you want it, it is not deformed. If you have brought, there is not much to say.
08.05.2020 20:11 # 14
dejawu1978
Double din came in the morning and I drew the project in my head, but unfortunately, there is a 0.5 cm gap on the sides, and the normal tape is in the curve inside the china, after cutting the upper and lower part, I will form a mold according to the double and take the fibergalass repair set there and fill it with it. It is 5.5 cm to hold but I think I can either print fiberglass again or finish the silicone so I think it will be solid ... I hope Big smile
08.05.2020 20:11 # 15
dejawu1978
or if it stays like this, would it be a problem ..? this is the unfilled side
08.05.2020 20:11 # 16
onlycihan
definitely fill it up personally, i dont like it.
08.05.2020 20:11 # 17
dejawu1978
[QUOTE = onlycihan] definitely fill it personally I don't like it at all, I recommend you to finish a clean job to stop it like this. [/ QUOTE]
I ordered it in the repair kit, just like I did in my self, I take small pictures until it is over. Wink
08.05.2020 20:11 # 18
Baran35
With the goodness that will be good, you are already in your mind. I like double tapes more than indash, but there is not much example for those who are able to do this in the 206's, so it is halal. I had seen it in a car. how is it unknown
08.05.2020 20:11 # 19
dejawu1978
I started from the bottom, I put it in practice, I put it in its place, the bowl is over. It was fine to fill the edges. It was like a stone in the ground.
08.05.2020 20:11 # 20
samet206
Use it beautifully, goodbye, the visuals are encouraging :) the only problem is the openings on the sides.
Page : / 2
