Cuts 307 cycles |
| 08.05.2020 14:15 | # 1 |
betonuur |
the catalatic convector lamp has started to light up. I took it to the exhauster, the floor is okay, but if the fuel is not fully lit, it will light the lamp here. |
| 08.05.2020 14:15 | # 2 |
betonuur |
this car 307 2006 1.4 gasoline
| 08.05.2020 14:15 | # 3 |
t@lip |
I think it needs to be connected to the computer, there could be so many reasons for this problem that I had resolved a close trouble by replacing the manifold sensor. First of all, make sure that the gasoline you receive is of quality, and if it does not, get it connected to the computer.
| 08.05.2020 14:15 | # 4 |
If the malfunction in the engine can cause serious problems, the vehicle brain automatically switches to protection mode. In other words, it cuts in 3000 rpm It does not allow the engine to start when you start further. First, the car must be connected to the computer |
| 08.05.2020 14:15 | # 5 |
betonuur |
I bought new gasoline, but I got out of a different place, I set off the road, this time the floor light did not come on and did not cut, now it is back to normal, if it is from gas, I will try a few more days, I burned the gas
| 08.05.2020 14:15 | # 6 |
my partner does not eat gas when the malfunction lamp lights up and does not pull himself or herself to protect himself, is this caused by fuel or when the engine gets cold, it gets better
| 08.05.2020 14:15 | # 7 |
mabolla |
is it overheating |
