cut off system
08.05.2020 17:13 # 1
bilalbaloglu
hello & nbsp; friends & nbsp ;, as we know & nbsp; new injection & nbsp; systems & nbsp; gas & nbsp; when the vehicle is in gear Pedal & nbsp; foot & nbsp; When taken & nbsp; fuel & nbsp; stream & nbsp; cut it & nbsp; "zero" fuel & nbsp; Spent.
This system is all & nbsp; injection & nbsp; systems & nbsp; is that valid ? mesala & nbsp; I have & nbsp; & nbsp; peug 2001 1.6 xt 8V 90 HP & nbsp; & nbsp; on these models, & nbsp; this system & nbsp; valid? & nbsp; a friend & nbsp; injection & nbsp; & nbsp; tool & nbsp; when the vehicle is in gear & nbsp; gas & nbsp; Pedal & nbsp; foot & nbsp; pull & nbsp; though trip computer & nbsp; 7.2 liter & nbsp; fuel & nbsp; was showing ..
on this topic & nbsp; & nbsp; you & nbsp; your car & nbsp; Status & nbsp; wonder what? & nbsp; bits & nbsp; my & nbsp; models in the car & nbsp; does this system exist? & nbsp; & nbsp; thanks ...
08.05.2020 17:13 # 2
Serkan
I know that it is available in all injection vehicles, when my 1.4 HDi car is on the gearshift when it comes out of the gas, the trip computer shows instant consumption 0.
08.05.2020 17:13 # 3
Alicilik
I know all ECU controlled injection vehicles are available.
I think the cut-off works after 1500 cycles. When going downhill, the speed increases when it goes below 1500 while it shows 0 fuel up to 1500. Sometimes it turns into a line when it shows 0 fuel for a very long time.
Since the trip computer does not drop to 0 immediately, I also drop to 0 in the half of the slope, so maybe it can be 7.2. Reviews
08.05.2020 17:13 # 4
bilalbaloglu
& nbsp; from this case, & nbsp; tool & nbsp; fuel & nbsp; farketmiyo & nbsp; diimine me .. & nbsp; tools & nbsp; lpg yle & nbsp; going in & nbsp; as & nbsp; systems & nbsp; continue & nbsp; Does it? & nbsp; Results & nbsp; LPG & nbsp; later & nbsp; takılıyom & nbsp; tool & nbsp; brain & nbsp; Able to detect & nbsp; this status .. & nbsp;
08.05.2020 17:13 # 5
Serkan
LPG INSTALLED FROM A MASTER THAT ASSEMBLY LPG
LPG injectors in Sequential Systems
LPG injectors stop working when the vehicle enters Cut-Off.
08.05.2020 17:13 # 6
bilalbaloglu
beautiful & nbsp; bi info & nbsp; serco .. car conscious & nbsp; use & nbsp; is an art & nbsp; & nbsp; & nbsp; .. but & nbsp; car & nbsp; I know how to use & nbsp; those who get along & nbsp; Most of the & nbsp; Status & nbsp; & nbsp; gas - brake - transmission & nbsp; & nbsp; halim & nbsp; in the form of smoke ..
by whom & nbsp; on vehicles 1700 & nbsp; In some & nbsp; while 1300 & nbsp; rev & nbsp; up & nbsp; systems & nbsp; valid .. well & nbsp; pegs & nbsp; general situation & nbsp; Does & nbsp; mesala & nbsp; & nbsp; 206 & nbsp; & nbsp; cut off un & nbsp; bottom & nbsp; Age & nbsp; how many & nbsp ;?
08.05.2020 17:13 # 7
Serkan
I do not have a clear knowledge of that kunu, but if I do not forget when I go to work in the evening, I will try and share the result here.
08.05.2020 17:13 # 8
bilalbaloglu
[QUOTE = Serco05] I do not have a clear knowledge of that kunu but if I do not forget when I go to work in the evening, I will try and share the result here. [/ QUOTE]
would be very good bro;)
08.05.2020 17:13 # 9
Alicilik
[QUOTE = bilalbalogl of] beautiful & nbsp; bi info & nbsp; serco .. car conscious & nbsp; use & nbsp; is an art & nbsp; & nbsp; & nbsp; .. but & nbsp; car & nbsp; I know how to use & nbsp; those who get along & nbsp; Most of the & nbsp; Status & nbsp; & nbsp; gas - brake - transmission & nbsp; & nbsp; halim & nbsp; in the form of smoke ..
mesala kimi & nbsp; on vehicles 1700 & nbsp; In some & nbsp; while 1300 & nbsp; rev & nbsp; up & nbsp; systems & nbsp; valid .. well & nbsp; pegs & nbsp; general situation & nbsp; Does & nbsp; mesala & nbsp; & nbsp; 206 & nbsp; & nbsp; cut off un & nbsp; bottom & nbsp; Age & nbsp; How many & nbsp ;?
You cannot tell the cut-off to the person driving with the carburetor mind "Smile"
I worked hard 50 years old, I could not tell my grandfather. I'm not showing the screen.
08.05.2020 17:13 # 10
Serkan
I tried between 1800-1000 cycles cut-off was enabled, trip computer showed 0 (zero).
