CUT FIRE SIGNAL
08.05.2020 19:58 # 1
skalkir
PARTNER 2007 1,6 HDI did not work any more after stopping my car.
THE STARTER CONVERTS BUT THE VEHICLE DOES NOT WORK ..?
WHAT SHOULD I DO I HAVE A OPPORTUNITY TO OPERATE TO THE SERVICE ..
NEAREST SERVICE 200 KM ..
08.05.2020 19:58 # 2
skalkir
Isn't there a master who can answer the above topic ..?
08.05.2020 19:58 # 3
talip206
Check fuses There is a definite overlooked situation. Especially if the fuse that controls the immobilizer is blown, the starter does not fire. If there is a Spare Key, first try with a spare Key, then check the Fuses under the steering wheel and in the Engine compartment. I know it happened the other day.
08.05.2020 19:58 # 4
The extra vehicle can air what our aspiring friend says. you should check this too.
08.05.2020 19:58 # 5
Kaan42
When the vehicle turns on the ignition, the immobilizer faulty or electronic maRS lock has been activated, the right key says Com 2000 fuses and it does not give any error from the life line.
08.05.2020 19:58 # 6
skalkir
Still, my problem is not solved. The brain went to the contact control. They said it is still, we are still dealing with the electrician.
08.05.2020 19:58 # 7
Well the crank position sensor was checked. Is fuel coming to the engine - injectors were checked. I gave the error code that I connected to the computer.
08.05.2020 19:58 # 8
skalkir
They said that fuel was not passing through the fuel pump.
I wonder if anybody knows how many money this is ..?
08.05.2020 19:58 # 9
My teacher between zero and 1500-2000 TL is an expensive piece
08.05.2020 19:58 # 10
skalkir
Friends, my problem is still not solved, the car is not working .. !!
The pump has also been repaired and repaired. They are now looking for malfunction in the brain.
This time they don't know the injectors and the pump, I think they say the brain .. !!
how this vehicle will work for 5 years so far, the vehicle has never had a problem with me.
We stopped the vehicle while it was in normal operation, we could not start again, it was not clearly diagnosed, I still could not understand .. everything is not working, how does it work ...
If anyone knows, please leave a comment and the vehicle is still in service ..
08.05.2020 19:58 # 11
Let my brother control the ecu (motor brain) with an exiting ecu. have a bsi check
