CRUZE CONTROL DISABLED
08.05.2020 19:50 # 1
ARDADOGAN
As a result of long researches, I got the speed stabilizer lever on the 2007 model 1.6 HDI 90HB car, but recently the car falls off to the off position when the cruise control is set to 80. I do not touch the clutch or the brake, then I pity again 10 20 seconds. The brand of the arm is VALEO, meaning it is not a fabricated arm made of shaved china.
08.05.2020 19:50 # 2
barishrocker
I was giving eror too, the problem was at the brake sensor. The brake light was also lit late. A cheap piece if it's the same problem ..
08.05.2020 19:50 # 3
ARDADOGAN
[QUOTE = barishrocker] I was giving eror too, the problem came out in the brake sensor. The brake light was also lit late. A cheap piece if it's the same problem .. [/ QUOTE]
Maybe it doesn't make much on the road like flat slider
08.05.2020 19:50 # 4
mistercasper
What about your print pad? When the clutch was at a fixed speed before changing the ramp or something, the clutch was missing when I missed a little clutch ... For example, when I go 90 with 90 on the straight road, it won't be a problem when I go with 90, but when I go to 90 with a constant like 110-120, the clutch is missing because of trying to accelerate suddenly. .
08.05.2020 19:50 # 5
ARDADOGAN
I made 10,000km of pressure pad zero or 10,000km
08.05.2020 19:50 # 6
Alicilik
Didn't the place you have made the fault detection?
Probably there is a fault record in the vehicle's brain.
08.05.2020 19:50 # 7
ARDADOGAN
[QUOTE = Receiving] Didn't the place where you had it done fault detection?
Probably there is a fault record in the vehicle's brain, have it checked for the situation. [/ QUOTE]
There is a gas pedal malfunction and it is not cleared. A week after activating the cruise control, I got the pc connected for egr. We realized that it was not deleted. They used their own program. It was not deleted . Then we disable speed stabilization and tried again. There is a malfunction. We did it again because we did not have a problem. Could it be because of the malfunction.
the ARDADOG 2016-06-08 21:43:40
08.05.2020 19:50 # 8
Alicilik
There is a problem with the pedal then or the limiter is opened, the car is falling into failure.
08.05.2020 19:50 # 9
ARDADOGAN
[QUOTE = Receiving] There is a problem with the pedal then or the limiter is opened, the car falls into malfunction. [/ QUOTE]
Connecting a pc and experienced the master, the situation that has no effect on the driving of the car is not in question, all the gas values are normal, but let's not clear the accelerator pedal malfunction is active.
