Cruise control to 307
08.05.2020 15:20 # 1
arslanbey01
friends I want to have my 1.6 1.6 comfort gasoline vehicle installed with curise control, the service said 50 TL, I found the speed stabilization and limiting arm, the service will put 50 TL, but I have a friend who does this work, how does it work between you? the thing said, what do you think is this bullshit? What kind of setting is there on the screen when I have curise control activated?
08.05.2020 15:20 # 2
There is a mistake that cannot be 50TL.
08.05.2020 15:20 # 3
arslanbey01
I take 50tl of workmanship speed stabilization lever myself
08.05.2020 15:20 # 4
Okay, I got it wrong.
08.05.2020 15:20 # 5
metin
[QUOTE = arslanbey01] friends 2006 1.6 comfort I want to have my gasoline vehicle installed with curise control service said 50 tl speed fixing and limiting lever I found the service will be 50 tl but I have a friend who does this work, how does it work between you and I wonder how does it work with my original? The service said a few things that belong to you. What kind of setting is on the screen when I have curise control activated, so what should I see on the trip computer screen when I make the curise control active?
There are already 4 speed fixing topics in the forum that only I know about. why do you open a subject without any research?
There are as many information in the forum as you would like as cruise control or cruise control.
08.05.2020 15:20 # 6
dinoco
[QUOTE = text] [QUOTE = arslanbey01] friends 2006 1.6 comfort I want to install curise control on my gasoline vehicle service said 50 TL, I found the speed stabilization and limiting lever, the service will fit 50 TL, but how do you have a friend doing this work, how does it work between you and how does it work with my original? I was wondering what the hell is this service for you. What kind of setting is on the screen when I have curise control activated, so what should I see on the trip computer screen when I make the curise control active?
Text you calm down :)) you don't get angry :) we all agree with you my friend :)) I haven't been given much answers already :)) I saw it, I wrote cvp when you wrote :)
08.05.2020 15:20 # 7
peugeotefe
I think that the friend may not have seen the subject, the site may not be following, you can help the friend by sending the link of the subject instead of behaving hard, or if you do not want to help, you do not need to write.
08.05.2020 15:20 # 8
metin
[QUOTE = peugeotefe] The friend may not have seen the subject, may not be following the site. Instead of acting hard, I think you can help the friend by sending the link of the subject or if you do not want to help, you do not need to write. [/ QUOTE]
friend has not seen the subject already at least 1 cruise control is always up to date, let me remind you first. In addition, when signing up to the site, the forum has its own rules, how we sleep, it will fit, not mine, you have to realize it.
I help you by giving a link first to you then (:
Article-6;)
08.05.2020 15:20 # 9
arslanbey01
If there is the same subject in there, it can be combined by the administrators or deleted by the administrator.
08.05.2020 15:20 # 10
friends please don't let each other be offensive
08.05.2020 15:20 # 11
metin
I have that authority, but I don't have a nap, I'm trying to warn. because we have made so many comments, we have shared information.
I http://forum.peugeotturkey.com/forum_posts.asp?tıd=14198&kw=cruise+control&title=206-14-hdi-hz-sabitleyici-takld-test-edil
here you have as much information as you would like, with all the answers to your cruise control system. you can even assemble it yourself when you get this information, or if you do not have a computer, you can teach and install it to a master who doesn't have a computer.
respects.
08.05.2020 15:20 # 12
Ozgur
As of yesterday, 2006 model 206 diesel speed stabilizer was installed.
I use it smoothly.
08.05.2020 15:20 # 13
metin
[QUOTE = Özgür] As of yesterday, 2006 model 206 diesel was fitted with cruise control.
I use it smoothly.
"Cc ---" should be going where the odometer is, did you look? I guess that this article should come out and work in 2006 and above models.
08.05.2020 15:20 # 14
Ozgur
There is no icon.
works normally but no icon or sign appeared.
08.05.2020 15:20 # 15
metin
Since the 2006 model 307s are a life system, they were dating, I thought that you were using a life system, and unfortunately I was wrong.
08.05.2020 15:20 # 16
d3n1s
[QUOTE = text] The 2006 model 307s are going out because they are a can system, I thought you were using a can system and unfortunately I was wrong. [/ QUOTE]
A member from here said that there was no CAN system in the 206s, but a master I asked also said that there was a CAN in my vehicle, I was thoroughly confused, the vehicle 206 quiksilver by the way
08.05.2020 15:20 # 17
iibrahimm
I got it, 1,4 hdi just doesn't show up on the screen
08.05.2020 15:20 # 18
metin
[QUOTE = iibrahimm] I got it 1.4 hdi just doesn't print the text on the screen
normal. However, whatever wisdom is not 140 TL, you get the vehicle zero and 600 TL if you get it on the screen (: They are doing a different software.
08.05.2020 15:20 # 19
arslanbey01
friends 2006 1.6 comfort gasoline vehicle, I used the speed stabilizer at 150 tl in the service as of today, I tested it, I tested it, it says cc on or of it on the km screen. But the speed limit did not work, so I have to change the accelerator pedal. When we put it in about 200 pounds, the speed limit worked. They just put it on for trial purposes and we saw it was removed.
08.05.2020 15:20 # 20
metin
[QUOTE = arslanbey01] friends 2006 1.6 comfort gasoline vehicle I used the speed stabilizer at the service costing 150 tl as of today, I tested it, I tested it on the km screen, it says cc on or of, and when I increase how many km it is fixed, I see all of them in detail. I think the system is very comfortable. But the speed limit did not work, so I need to change the accelerator pedal, when we put it in about 200 pounds, the speed limit worked, they just put it on for trial purposes and we saw that it was disassembled.
I think the vehicle is a make-up case, the make-up safes are a system, and the information on the screen appears. If you cost 150 TL including the arm, it is very good, but you would say that there was a handle, and 150 TL, except the arm, was a little expensive.
Apart from that, your fixing arm is the wrong arm, hence fixing to 307s, there is no speed limit. speed limiters sleep in 308s so it's normal for you not to work. we have learned something more alone. Thanks to this information, it was possible to install cruise control with speed limit in 307s when changing the gas pad.
good luck use it.
Page : / 5
