Cruise control
08.05.2020 21:30 # 1
baris1919
I bought a restricted arm on aliexpress. I opened it from PC. Let's say lim 50 says on the display screen. When the speed exceeds 50, it just flashes and doesn't keep the vehicle at that speed. As for the Cc menu, it shows the current speed for only 1 second as soon as it is activated, then goes off and always shows "---" sign. What could be the problem.
The vehicle is a 2004 station, the brake sensor has 4 pins and 5 cables.
08.05.2020 21:30 # 2
Limiting does not work, my teacher is in your vehicle. only cruze control opens. Some versions of it have to check can be this nuisance. Make the limit from pp passive. If there is a part about limit, it may be that you have activated it.
08.05.2020 21:30 # 3
baris1919
Unfortunately, it didn't happen when I tried to remove the limt and just open the Cruise.
08.05.2020 21:30 # 4
As I said, our recruiting moderator in the forum is very experienced, cables etc. Although it may be in a situation related to bsi or motor ecu, hodja. Send a private message to him and he will answer.
08.05.2020 21:30 # 5
baris1919
thank you.
08.05.2020 21:30 # 6
Alicilik
Hi
Is your vehicle diesel or gasoline?
In 2004-2005 1.6 diesels, it is necessary to shoot installation systems.
2004-2005 1.6 gasoline does not work if it should not be displayed on the screen
0537 380 32 86 from whatsapp, I will help you with your settings.
08.05.2020 21:30 # 7
Orcun.Dmr
[QUOTE = groundcover] Hi
0537 380 32 86, I will help you to set up on WhatsApp. [/ QUOTE]
Is the 2005 model 1.4 HDi engine also active? I'm not sure if 4 or 5 cables were entering the brake coupler.
