cruise control
08.05.2020 20:24 # 1
hrn 63
Hi aleykum friends, first of all, good Ramadan ..
2010 308 1.6 HDI AUTO6R I want to install a cruise control, but around 450 TL in the service ... even the master in the service, take the handle from the outside, I said we can handle it here.
thanks in advance ....
08.05.2020 20:24 # 2
uzunca961
[QUOTE = hrn 63] Hi, my friends, firstly, Ramadan.
My land is the same as your car. I bought it on aliexpress last year. He came in a week. We have $ 20 now
But I know it is forbidden to hang in the service.
the part code should be this: 6242Z8
And don't forget that let both speed stabilization and speed limiting activate the program.
uzunca961 2017-06-13 13:02:30
08.05.2020 20:24 # 3
hrn 63
First of all, thank you, my land .... it is forbidden in the service, but I need to update it while doing it in the service. the mechanism is attached the room is expensive hrn 63 2017-06-13 13:27:18
08.05.2020 20:24 # 4
uzunca961
[QUOTE = hrn 63] First of all, thank you soil .... it is forbidden in the service but I need to update it while doing it in the service. a mechanism is installed on the brake pedal or something [/ QUOTE]
Thank God so far, no problem has been on the arm I bought.
I did not do anything else on the car other than the arm. they just wore the arm, they activated it with the program, so much of control and fixation.
What is the update for, by the way, if it's not installed on mine, let me get it
08.05.2020 20:24 # 5
hrn 63
If it was only with the program, he said well then he was not a master in service. I place an order then trusting you too. Smile
In the update; while the car was being balanced at the service, the wipers worked and the quads started flashing. Then he took out the end of the battery, waited for a while, then connected it to the computer and formatted the brain.
08.05.2020 20:24 # 6
uzunca961
[QUOTE = hrn 63] said that if it was only with the program then it is not good at the service then. I place an order then trusting you too. Smile
I hope it will happen to you as I do
I hadn't heard of that update. I wonder if there is anything extra in the update
08.05.2020 20:24 # 7
ggitaristt
Guys, If your car burns normally and runs smoothly, do not touch it .. Do not update or do anything ..
08.05.2020 20:24 # 8
hrn 63
I read it a little late, my friend wrote it ... I updated it, and there was a problem with the fuel, I couldn't understand it burns more than usual ...
08.05.2020 20:24 # 9
uzunca961
[QUOTE = hrn 63] I read it a little late, my friend wrote it ... I updated it and I really couldn't make sense that it was a fuel problem.
I did not understand this event. What is the update done for?
08.05.2020 20:24 # 10
hrn 63
As you said, if I understand, I don't eat a gambler, give 120 lira, update it.
08.05.2020 20:24 # 11
spycan
My 308 1.6 vti (2012) cruise control 4-5. This is the reason why it doesn't work in gear. Does anyone have information
08.05.2020 20:24 # 12
hrn 63
There may be a problem with the software.
08.05.2020 20:24 # 13
[QUOTE = spycan] 308 1.6 vti (2012) my cruise control 4-5. This is the reason why it doesn't work in gear. Does anyone have information
the brake sensor is probably broken. but as our friend said, connect the pc and have it checked. Have a look at the line codes.
08.05.2020 20:24 # 14
GokhaN
Important at the speed you go does not work under 70km in our vehicles
08.05.2020 20:24 # 15
spycan
I took the car to the service last week, everything looked normal on the computer. The first time I came across the master in the service, he said. let's see we will continue research
08.05.2020 20:24 # 16
ZIYA SAHINDOGAN
Masters yesterday 2008 model 308 I bought the comfort package 16v but no speed stabilization, I will get the lever, which number should I get and as far as I research it, it is suitable for automatic gear vehicles.
08.05.2020 20:24 # 17
maximusti
[QUOTE = ZİYA ŞAHİNDOĞAN] masters yesterday 2008 model 308 bought comfort package 16v but no speed fixing, I will get the handle which number should I buy it and as far as I searched from the net, it is suitable for automatic gear vehicles. Thank you. [/ QUOTE]
The product code also includes the part code, 308de part code 6242.Z9 with this code you can get the products from aliex .
The automatic stabilizer also works, but speed limitation may not work.
Check the cable to the Firen client, it must be a 4 wire socket.
After the arm is attached, it must be opened with a computer.
08.05.2020 20:24 # 18
First of all, welcome to us. our friend made the necessary explanations. If you can come to Ankara, we will have a friend from the forum.
08.05.2020 20:24 # 19
ZIYA SAHINDOGAN
Thank you for your help, so how do I activate this arm from the computer, is it not working manually? I am a little new about these issues. ? ZİYA ŞAHİNDOĞAN 2018-03-13 11:56:48
08.05.2020 20:24 # 20
husem
You need the diagbox program and actia cable to activate it. You can understand what happened by looking at the code from the diagbox in the error you received.
