Cricket cricket
08.05.2020 17:01 # 1
chnyalcin
Hello friends;
The sound of the Peugeot 206 right in front is intense like a cricket. I did not do anything because I thought it was time to change the tires before, I changed 4 tires 2 days ago, this time the sound increased. I am in the forest Cır cır cır cır cır cırır :))) What do you think should I do?
08.05.2020 17:01 # 2
dukenukem82
You have either received a new and bad brand, or a warning that you are finished. Linings with a large metal mixture crow a whisker.
08.05.2020 17:01 # 3
chnyalcin
Ooo this is a serious problem. It's been 1 month since I bought the car. Now in the 67000s. I didn't know that my friend changed the pads in 60.000.
08.05.2020 17:01 # 4
If this noise is heard when you apply the brake, you can support the brake assembly, but if it keeps coming and the noise increases with the face, you should look at the wheel bearing.
08.05.2020 17:01 # 5
chnyalcin
No bro. There is no sound when I press the brake. The vehicle comes regularly while on the move.
08.05.2020 17:01 # 6
impact
Does the sound stop when it speeds up?
08.05.2020 17:01 # 7
chnyalcin
As if I'm not sure exactly because I got angry and unmute the music :)))
08.05.2020 17:01 # 8
dukenukem82
I thought I had fallen to the bird paradise you know I bought Turkish goods, cik cik cik cik :))
Then, when I bought a foreign brand, I got rid of the birds. The brake system, which was working with friction by squeezing slightly without applying the brake, therefore, the pads with a high percentage of metal make such sounds.
08.05.2020 17:01 # 9
chnyalcin
Hahahhhhah :))) I'm taking it this afternoon, pilgrims. I already started scratching.
08.05.2020 17:01 # 10
istanbullu_3886
Is the vehicle coming while stationary or is it on the move?
08.05.2020 17:01 # 11
impact
Mine is the original bidet. I start to sound when I touch the brake, I get very nervous, and if my back is available, I suddenly brake and stop "Cool" & nbsp; there is no peace :)
08.05.2020 17:01 # 12
chnyalcin
No pilgrims while the vehicle is stationary. It starts to creak when the movement starts. After the 3rd gear, I don't hear the tape because I pressed forever but there is no sound to listen to today.
08.05.2020 17:01 # 13
istanbullu_3886
I think that if the sound is on the move, it is likely to end the pad, or the sound of the bearing may be from the tension ball if the motor stops while it is running.
08.05.2020 17:01 # 14
mmuussaa
I have a sound after exceeding 100km. I wonder why brake pads have just changed?
08.05.2020 17:01 # 15
chnyalcin
Friends, I just came from the service. There are handle-like wires on both ends of the brake lining. There was no problem other than that. For your information.
08.05.2020 17:01 # 16
valeryzone
I have 206 Gti VAr in the same sound I have in Bend VAR Brake is not pressed or stopped
I would say a problem with suspension when passing through the pits or bumps but
I think there is a problem with the tire or wheel bolts when I move the car, but I still couldn't solve the sound coming & nbsp;
08.05.2020 17:01 # 17
istanbullu_3886
[QUOTE = mmuussaa] I have a sound after exceeding 100km. I wonder why brake pads have just changed? [/ QUOTE] I think your discs are dead bro!
08.05.2020 17:01 # 18
istanbullu_3886
[QUOTE = chnyalcin] Guys, I just got back from the service. There are handle-like wires on both ends of the brake lining. There was no problem other than that. For your information. [/ QUOTE] should be the fixing wire of the pad
08.05.2020 17:01 # 19
chnyalcin
It was just like fixing wire. & Nbsp;
08.05.2020 17:01 # 20
Femida
[QUOTE = chnyalcin] Just as it was due to the fixing wire. & Nbsp; [/ QUOTE]
How much did it cost?
Page : / 2
