creaking noise from the tailgate !!!
08.05.2020 16:01 # 1
tilbe307
While friends 307`s vehicle was in motion, there was a constant squeaking by the luggage. tell me the problem.
tilbe307 2011-08-20 11:08:15
08.05.2020 16:01 # 2
tilbe307
Uploaded with ImageShack.us
we unscrew the screw ...
08.05.2020 16:01 # 3
tilbe307
After unscrewing the screw on both sides, we remove the plastic coating on the cover of the mount.
08.05.2020 16:01 # 4
tilbe307
We lubricate these iron pieces on the plastic part with grease and reattach the disassembled part. no more creaking problem ...
08.05.2020 16:01 # 5
Congratulations, I hear the sound when opening the hood. It is necessary to lubricate the lift arms used in the trunk, what kind of oil should be used in this?
Thank you...
08.05.2020 16:01 # 6
gozem
this information will work very well, thanks ..
08.05.2020 16:01 # 7
34sea45
[QUOTE = HeRo1727] Congratulations, I hear the sound when opening the bonnet. It is necessary to lubricate the lifting arms used in the trunk, what kind of oil should be used in this?
Thank you...
the machine oil they use in sewing machines is working
08.05.2020 16:01 # 8
Thank you Dinçer, thank you ...
08.05.2020 16:01 # 9
tilbe307
I used grease but if it is in an open place because it is closed, then the sewing machine oil works in my opinion :)
08.05.2020 16:01 # 10
sifremi unuttum
No grease, use thin oil. Grease collects dust
08.05.2020 16:01 # 11
altugg34
Teacher, I have the same problem, as you said, I removed the black cap and lubricated those metals, but the squeak continues. sounds coming. It doesn't always happen when passing through the hood. Do you have any other suggestions?
08.05.2020 16:01 # 12
SZKR
It was good, I learned, it is high ...
08.05.2020 16:01 # 13
altugg34
It doesn't always happen to me. The sound coming in E5 is the creaking sound on the left side of my tailgate. Is there any idea or solution?
08.05.2020 16:01 # 14
dRhkn
I also suffer from the same problem. Is the road a little broken? No sound is missing from the back left of the trunk
08.05.2020 16:01 # 15
katipahmet
Ahhh, that voice ahhhh killed me
08.05.2020 16:01 # 16
hakan38
Thanks, my teacher, we are from the same distress. When I put the seat down for the victim, the seats turned out to be too low. There is a voice. My own voice is not heard.
08.05.2020 16:01 # 17
_semihk_
the kdr on my forehead :( I changed the baggage wicks to the trunk, it is still not cut
08.05.2020 16:01 # 18
altugg34
The squeak does not always come to me, for example, it does not come when the mound passes, but when the prime is broken in E5 or Tem, the metal squeaking is coming by the left trunk lid. The black part on the cover sat a little hard, but it sat down :) There was a gap where there was a rear brake light on the trunk cover, I put a sponge there. I took it to a master in the industry. put a cable in between and took the gap, but the sound did not stop :)
08.05.2020 16:01 # 19
arachnid
I dealt it like this. I glued a 4mm plastic wedge with adhesive on one side where the plastic wedges on the sides of the tailgate touch the chassis. It goes on for 4-5 months and then I stick it again. (I used it from the feet attached to the computer case.)
08.05.2020 16:01 # 20
altugg34
[QUOTE = arachnid] I got it like this. I glued a 4mm plastic wedge with adhesive on one side where the plastic wedges on the sides of the tailgate touch the chassis. It goes on for 4-5 months and then I stick it again. (I used it from the feet attached to the computer case.) [/ QUOTE]
Do you attach this wedge to the place where Black round plastics that appear in the first message correspond to the corresponding place when closing the baggage? Did you have metal grinding too?
Page : / 2
