crankshaft sensor. partner |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner | |
| 08.05.2020 16:22 | # 1 |
aopena |
the second issue is that the fault lights are on the show constantly, the lights are on and the two fault lights are flashing. this problem started to bother me thoroughly ... what are your ideas & nbsp;
| 08.05.2020 16:22 | # 2 |
How many engines is your vehicle 1.9 or 2.0? |
| 08.05.2020 16:22 | # 3 |
aopena |
2.0 HDI engine & nbsp;
| 08.05.2020 16:22 | # 4 |
Is there a problem with the vehicle traction? also my camshaft reader voland reader you installed? If your vehicle is 2.0 hdi, the voland reader is just above the transmission, it is black. If the malfunction lamp is on, when it is connected to the device, it will surely not fail 0
| 08.05.2020 16:22 | # 5 |
aopena |
they were removed from the right side of the engine, also the 20th hdi is written as a flywheel sensor.
| 08.05.2020 16:22 | # 6 |
You say the malfunction light is on, is there any problem when the car is connected to the machine?
| 08.05.2020 16:22 | # 7 |
aopena |
that light is flashing like a love, it is as if it is blinking as if it is a non-contact, all of a sudden it turns on, it turns on, sometimes it stops, it lights up when it starts, it turns off when it stops, it turns on when the ignition is turned on, it generally disappears when it runs cold in the cold, and it sounds like it beeps when it is overloaded and a warning lamp is on, I think I couldn't solve it There is also a problem in the equipments & nbsp; for example the lights in the picture in the link 17 & nbsp; 18 & nbsp; are lit both occasionally & nbsp; |
